Front end squeak...
Old Oct 24, 2001 | 07:23 PM
GlockLT4's Avatar
GlockLT4
Default Front end squeak...
I've got a front end squeak (not the brakes - that is taken care of).. It is VERY noticeable when going over small bumps. I checked the sway bar, pulled up and down on it as much as I could.. couldn't get it to make any noise (probably because I greased the hell out of it about 2 months ago - grease is still visable).
I greased up my ball joints at the same time (2 months ago), so they shouldn't be making the noise.
What else should I check? It's high pitched, and pretty loud outside the car... i hear the sound waves bouncing off things around me when i drive with the windows down. It doesn't sound like it's from a wheel... sounds more like it's from the center front area of the car.
Thanks!
[Modified by Glock'94, 5:23 PM 10/24/2001]
Old Oct 24, 2001 | 10:28 PM
Corvette0096's Avatar
Corvette0096
Default Re: Front end squeak... (Glock'94)
If i where to guess i would say, Sway bar bushings.......The two in the center that hold them on the frame........Just did this last week. Mine would make a nastey sound when i went over a speed bump.
Old Oct 24, 2001 | 10:36 PM
turbota's Avatar
turbota
I had the same problem in my 89 GTA. Going over dips in the road the car would creak and squeak. Turned out to be the bushings.
Old Oct 24, 2001 | 10:45 PM
R23HTC's Avatar
R23HTC
Default Re: Front end squeak... (turbota)
I'd say the sway bar bushing holding the front bar to the frame. I've had to do mine 3 times now. Last time I used wheel bearing grease! Just another one of those things on the list for replacement. Polyurethane rebuild in the future.
Old Oct 25, 2001 | 01:00 AM
JasonL's Avatar
JasonL
When you say you checked the sway bar, did you disconnect both endlinks and then rotate the sway bar within the frame bushings? It should then immediately be obvious if that is the culprit. Yeah I know you greased it already... :)
Old Oct 25, 2001 | 01:13 AM
GlockLT4's Avatar
GlockLT4
Default Re: Front end squeak... (JasonL)
No, didn't do that. But like I said, I did push and pull the entire front end of the car so that it moves more than it does when it makes the noise. I also went underneath the car and did an up side down push up rasing the car up listening for noise... and nothin...
I'm still stumped... :confused:
Old Oct 25, 2001 | 01:42 AM
moffitt's Avatar
moffitt
Wrapping the sway bar with teflon tape where the bushing contact is made is GM's solution to squeeks.
Old Oct 25, 2001 | 02:56 AM
GlockLT4's Avatar
GlockLT4
Default Re: Front end squeak... (moffitt)
Ah... good tip (if indeed it is the sway bar)
To Front end squeak...
