Ignition Module Ground Circuit
Old Jun 7, 2007 | 08:13 AM
topspin's Avatar
topspin
Default Ignition Module Ground Circuit
On 96 LT-1, if you unplug ign mod connector and check for ground with test light or ohm meter, should the blk/wht wire show ground with the key switched to the On position. I have this wire grounded with key off and on. I beleive this is grounding out this circuit while my car is cranking causing a no fire to the ign coil. Where does the blk/wht wire connect to????
