From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Did they both tuck under to begin with? I assume mine did from the factory yet the passenger side sits exposed. I have adjusted them down as far as I can go and as close together without hitting.
There's no play in the linkage either.
I give up.
(And yes the park feature works fine and the plastic stops are all the way down.)
[QUOTE=CentralCoaster;1560564782]Did they both tuck under to begin with? I assume mine did from the factory yet the passenger side sits exposed. I have adjusted them down as far as I can go and as close together without hitting.
QUOTE]
Not really, my stock pass side has alway stuck up little, I will check this adjustment feature tonight
