96 AC Trouble
Old Oct 25, 2001 | 01:23 AM
Cruisin96CE's Avatar
Cruisin96CE
2nd Gear
Default 96 AC Trouble
Everyone here seems extremely helpful, so I ask for help with this situation. Started with a dead battery about a week ago. Not sure what caused it, but after a charge and jump, I was on my way to work. That night driving home, I'm getting the flashing "sys" on the CCM, and when stopped at stoplights, everything dims, and the voltmeter drops low. Had to drop into neutral and rev it several times (yes, it's an automatic; sorry) just to keep from stalling. Check the codes when I get home (paper-clip method) and I'm getting 31, 33, 35, and 37, all current and none in the history. Replaced the battery, and everything starts fine with no more codes, but now the ac/heater will only blow through the windshield and foot vents and not the dash, no matter what settings. AC and heater both seem to work. Fuses look ok but I'm not a wiz at working on this baby and may be missing something. Any suggestions? Was something fried when I jumped it?
Old Oct 25, 2001 | 11:15 AM
thedevl's Avatar
thedevl
Default Re: 96 AC Trouble (Cruisin96CE)
Have your alternater tested. If it's good, then try resetting by unhooking battery for 10 min or so. My AC is weird sometimes, but usually the next time I start the car, it will be ok.
Good luck
THEDEVL :reddevil
Old Oct 25, 2001 | 02:13 PM
FrankLT4CE's Avatar
FrankLT4CE
My 96 acts the same way ie only blows thru the defroster and feet outlets, but I'm not sure of the cause, but think my condition is mechanical, ie stuck vacuum actuator valve. Your cause seems to be related to a bad battery. But I am not sure. If related to the battery problem then maybe you did fry the AC Controller (the rectangular panel that you push the buttons on to direct the air flow) or the AC programmer (the black box above the drivers foot that has the tan, pink, blue, orange, and black vacuum lines coming from it). The 96 factory manual has detailed instructions (in about 4 different sections) so you could test to try to pinpoint the problem. There are troubleshooting flow charts to use. Some of the tests are not easy. IP removal is necessary for some tests. For some tests a special scanner? that a dealer would have is needed. I hope this info helps. Good luck. Let us know what you find. FrankLT4CE
Old Oct 25, 2001 | 08:38 PM
Cruisin96CE
2nd Gear
thanks all. I appreciate the comments and suggestions. It may take a trip to the dealer to check further, but I'll let you know what I find.
Old Oct 25, 2001 | 09:31 PM
04Z16's Avatar
04Z16
CI 3-4-5-6-7-8-9-10 Veteran
This is a common problem when the electronic AC control fails. It is about $400 to have the dealer replace it. The other thing could be the door is stuck. There was a forum thread on this a while back. You might want to check the archives.
Leo
Old Oct 26, 2001 | 01:28 PM
Mac78and2K's Avatar
Mac78and2K
Default Re: 96 AC Trouble (96GrandSport)
If I remember correctly, these was a post a few months ago about this exact situation and it turned out to be a bad Vacuum (module/valve) in the engine compartment next to the firewall. A $7 fix. Hope this is all that is wrong with yours.
Old Oct 26, 2001 | 06:07 PM
catdaddy's Avatar
catdaddy
I had the same problem when I bought my car. The dealer fixed as part of the agreement. The a/c mechanic said that some of the vacuum lines were pinched. Just a afterthought.
To 96 AC Trouble
