lowering my "95" I need some help
Old Oct 25, 2001 | 03:57 AM
gottaspeed's Avatar
gottaspeed
Default lowering my "95" I need some help
I got the kit from mid america. I've got the front spring out. I have begun removing the rubber blocks from the spring. I see the wedges that came with the kit. it doesn't like i will get much of a lowered stance with the wedge that is to replace the rubber block? did anyone not use the wedge and just put it back together with none at all? It is only 1/2 an inch difference from the stock rubber block and the wedge supplied in the kit. all suggestions welcome. thanks
Old Oct 25, 2001 | 05:58 AM
C4396roadster's Avatar
C4396roadster
Default Re: lowering my "95" I need some help (gottaspeed)
You might as well put in the wedges I tried it both ways and there was no diff so I elected to put them back in so it would ride on the poly instead of the spring. :cheers:
Old Oct 25, 2001 | 01:28 PM
gottaspeed's Avatar
gottaspeed
Default Re: lowering my "95" I need some help (C4396roadster)
4396roadster- thanks, how much did it lower your front end?
Old Oct 25, 2001 | 01:42 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
I did not use the wedges. I simply left them off. It gets you another ~1/4-1/2" lower. If you want it even lower, you can remove the other pads from the tips ofthe spring/mounting positions. Some have quite a bit of extra height because of the ends.If you leave the wedges off, it is really low.
To lowering my "95" I need some help
