I did my injectors over the last weekend, dis-connected the battery cable. My wife dropped the car off to have state inspection done today, she says the radio does not work now? Could I have fried a fuse?
When the power is removed from the Bose system, it will default to its "Anti-Theft" feature.
Assuming nobody has ever put in their own security code , you can unlock the system using the following steps:
1. Turn ignition on.
2. Press "Set". "000" should appear on the display.
3. Press "AM/FM". the clock display should appear and the radio can be turned on. If "LOC" appears on the display, the default code "000" has been changed and you will need the new code to unlock the security system.
Look at pages 178 thru 180 of the Owners Manual for further instructions and explanation.
