Checking fuel flow in 84
Old Jun 8, 2007 | 01:03 PM
Richard J.'s Avatar
Richard J.
Cruising
Default Checking fuel flow in 84
I cant believe this ..everything was going fine and I shut off the engine and come back and it wont start . I took filter off ..it was good but cleaned it anyway . I do not feel the pump is bad ,is there an easy way to check or identify the problem? Thanks ...Richard
Old Jun 8, 2007 | 02:08 PM
CFI-EFI's Avatar
CFI-EFI
Does it crank? If so, what is missing? Air? fuel? Spark?
RACE ON!!!
Old Jun 8, 2007 | 04:03 PM
Richard J.'s Avatar
Richard J.
Cruising
Default Got it
Well ,checked the fuel line and fuel filter ,it runs again .Dont know exactly what or how I did it but its running again .so be it. Richard
Old Jun 9, 2007 | 12:17 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
It may be a good idea to just see what FP you are running. Check it between the TBs. 14psi works best for a stock or slightly modded CFI motor. You may not have a bad pump, but you may need to bump up the FP at the regulator on rear TB. If the pump is weak, replace it with an 85 vette pump, direct swap.
Old Jun 9, 2007 | 01:19 PM
CFI-EFI's Avatar
CFI-EFI
The spec on the fuel pressure of the '84 is 9 to 13 PSI. If the fuel pressure does not drop from idle to the highest attained RPMs under the highest load, the fuel pump is doing it's job admirably.
RACE ON!!!
Old Jun 9, 2007 | 07:24 PM
Richard J.'s Avatar
Richard J.
Cruising
Default Thanks all
I very greatful for the information recieved . Thank You ///Richard
I drove it today ...dang it was fun ...just need to head off any more problems with the fuel flow ...I will read up on the tools needed and the how to do it kinda thing . Thanks again .
To Checking fuel flow in 84
