Antifreeze/Coolant Question(s)
If the car came with glycol, stick with glycol. If it has Dexcool, stick
with Dexcool. The two coolants are incompatible, numerous expensive
issues arising from mixing them are mattes of public record and lawsuits.
You can't flush Dexcool completely from a system, even if you succeeded
there would still be residue from the coolant that had seeped into gaskets
and hoses. People have suggested changing over after a total rebuild
- what about the heater, radiator, water pump and so on?
If still unconvinced, then at least search the archives here and on
the web before proceeding
As for the 'compatible with everything' coolants: sorry, I have no
confidence that I would ever be able to collect if they turned out to
be incompatible. I couldn't be convinced to trust and try.
So why not use the newer coolant and eventually the Dexcool will be mostly gone.
Deionized water = Reverse Osmosis = Filtered to remove minerals, bacteria, etc. Used to desalinate water. Aggressive to metals.
Distilled water = Boiled to remove minerals and bacteria. Cleaner than Deionized, but more expensive. More aggressive to metals.
When deionized water or distilled water is used in a lab, the pipes are always plastic.
You can't win with water. It's a very nasty chemical, but it's damn good at cooling. (WATER IS NOT A CHEMICAL)
The antifreeze is there to do everything the water can't, in this order: Resist corrosion, lower freezing temps, and increase boiling temps.
FOR CORROSION TO OCCUR THREE REQUIREMENTS MUST BE MET:
1.The metal needs to be in contact with an electrolyte. (DEFINITION: ELECTROLYTES ARE SOLUTIONS WHICH CONDUCT ELECTRICAL CURRENT AND SUPPORT IONIZED PARTICLES.) Usually the electrolyte is water but other liquids as well as gases in some instances may serve as electrolytes as well.
2.The presence of dissolved substances in the electrolyte is necessary. These substances can be dissolved gases such as oxygen, chlorine or bromine gases or dissolved ions such as H+ (hydrogen ion) all of which serve as strong corrosive agents. Pure distilled water with no dissolved substances will not function as an electrolyte and metals subjected to it will not corrode.
3.The presence of a corrosion cell whereby two portions of the metal surfaces become electrically connected via an electrolyte, salt bridge etc. A portion of the metal surface then becomes anodic (corrodes) giving up metal ions and another portion becomes cathodic, gaining metal ions.
It appears that adding distilled water to a coolant with a rust inhibiter would be benificial to the longevity of a radiator. I would also change it every two years. Over time the distilled water will pick up minerals from engine parts. Change the coolant and flush the system to keep it clean.
As far as I know, distilling gets you more organic purity, but not as much ionic purity. So it's not as aggressive as deionized water. But it's also more conductive.
DI water is more for lab purity where dissolved metals can harm experiments. Distilled is more for drinking / sanitizing to remove bacteria.
You can have aggressive water, or you can have conductive water. Pick one. The water wants to have ions in it. If you remove them, it will get them from somewhere else. I would also avoid using websites that are hawking crap as a scientific reference.
Like you, I also don't buy the "compatible with all" coolant BS either. It just doesn't add up with what I have learned about coolant types over the years.
If you buy coolant that is pre-mixed, look at the bottle. It will say they mixed it with de-ionized water (distilled is expensive). I am not sure they'd do that if it weren't the appropriate way to mix coolant.
I agree though, there's more to evaluating coolant than checking the ratio. If you have doubts about the coolant, drain it out and refill it. It's neither hard to do, nor particularly expensive, and a lot is riding on it doing its job. FWIW to the original poster, my car takes about 3 gallons of coolant, though we don't have the same engine.
If you have a brand new battery that is empty (marine/deep cycle batteries are sometimes sold this way), and you put nothing but distilled water in there, I doubt it would ever hold a charge. You fill it initially with battery acid. Then afterwards you can maintain it with distilled water.
But it will dissolve the metals in your system, and become an electrolyte at the expense of your metals.
....all capacities, fans, burping, EVERYTHING etc was done properly.
....however, the ONLY difference from when i started to the end result was that i did NOT add a bottle of WATER WETTER......i am now curious as to if that could be the contributing factor as it says that the stuff lowers temps 10* +/-....any reasonable opinions?....
