Steering Wheel Loose
Old Jun 9, 2007 | 12:02 PM
FussBudget's Avatar
FussBudget
Default Steering Wheel Loose
I have a 1993 coupe and the steering wheel tilt mechanism is loose. The wheel has a lot of play in it. I can move it about 2 inches from 2 - 8 o'clock. I failed inspection - the inspector said the wheel may fall off - which I doubt.... It seems as if the tilt lever is allowing too much play or else the bolts are loose holding the tilt mechanism in place. Any ideas? Thanks.
Jim
Old Jun 9, 2007 | 12:34 PM
ineVETTEable's Avatar
ineVETTEable
Same thing here, I believe it's a problem with the tilt knuckle. And i believe it comes from people pushing and pulling on the steering wheel entering and exiting the car. It also seems to me it's not and easy fix as the air bag and plastic blinker stuff and all the rest of the crap in there needs to be removed just to get at the knuckel, which likely comes as a unit. (steering column) Too bad the knuckel head at the DMV caught it.
Old Jun 9, 2007 | 01:23 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
http://domesticmisfits.net/forums/vi...ring+clumn+fix
Old Jun 9, 2007 | 03:39 PM
FussBudget's Avatar
FussBudget
Thanks guys. I don't think I want to do this myself.... too much fuss.
Old Jun 9, 2007 | 09:27 PM
TripleBlack88's Avatar
TripleBlack88
Jim,
You may find that the parts needed are no longer available. I had the same problem on my '88 and had to buy a used column for the parts I needed.
Good Luck,
Ed
Old Jun 10, 2007 | 05:00 AM
steve40th's Avatar
steve40th
Originally Posted by TripleBlack88
Jim,
Good Luck,
Ed
Chris May at the Chevy dealership helped me allot with the parts, which most (at least the ones you need) are available.
Old Jun 10, 2007 | 11:57 AM
2012 coupe's Avatar
2012 coupe
Default Tilt wheel part #
Here is the GM part # for the repair kit for your problem steering wheel:
26002678 Spring Kit-Tilt
As far as I know it is still available.
Old Jul 2, 2007 | 09:28 PM
FussBudget's Avatar
FussBudget
You guys are GREAT!
Old Jan 5, 2008 | 10:55 PM
cjdietzman's Avatar
cjdietzman
Default 1990 Vette Steering Column Question
Hey Guys,
I have a 1990, auto, with airbag. My steering column is also loose. Question: Would the column parts and repair process be the same for my 1990 as what is listed in the link that you provided below? Has anyone replaired a loose column on a 1990 auto with airbag? I have never done this type of repair to my vette. Any insight would be appreciated. Thanks!
HEre is the link that I was referring to:
Old Jan 6, 2008 | 03:05 AM
steve40th's Avatar
steve40th
Chris Said this is all I needed, Bought a couple months ago
To Steering Wheel Loose
