1990 350 vett wont start after worme up until cool down
i am having trouble with my 1990 350 the car runs fine until it warms up then it cuts off like it ran out of gas and wont restart until it cools off again . I replaced fuel pump and filter what else should I check.i have a HEI dis. changed coil check for spark it is good had moduel checked it is good. does any one know what problenms too look for if computer is bad how to tell, I donot have any trouble codes stored or no check engine light on maybe this is the problem would like to know how before I go out and buy one.
thanks for the help
thanks for the help
Last edited by dollarbillion; 06-09-2007 at 08:55 PM. Reason: more info on what i have done
Quite honestly I don't know if the 90 has an Opti or a HEI distributor, but if it has the HEI I'd have the ignition control module checked. When they're on the way out they typically raise their ugly heads after the engine has warmed up.
This is a common problem.
Ignition module.
