LT1 w/old style distributor
No owner in sight to ask. Have any of you guys seen this before?
So I'd say the lt1 could be made to use a rear distributor.
If you look at the back of the engine you will see the oil pump drive.
www.tpis.com sells it.
It looks ALOT like the LT1 intake,but has water jackets in the intake manifold while the actual LT1 does not,to use with older sbc head design.
I also wondered in the past if someone with a LT1,installing a distributor,if it would be beneficial over the opti.Would be cool if someone sold a wire harness kit/oil drive parts to hook it up and made it work.Would be a far cheaper cost alternative in the long run.
(ECM , wiring ,dist ) it would work.
Have to do the same intake mod to mount the dist as mentioned above..
The opti is difficult to work on due to location; however, most optis provide tens of thousands of miles of trouble free operation (some have more than a 100K on them.)
It seems that when someone has LT1 problems, a bunch of people start to post "check the opti" even for problems that could never be ignition related. Some people have problems with their OPTIs however, if the opti is as bad as its reputation how come most 92-96 LTX corvettes/F-bodies and B-bodies have soooo many miles on them.
The standard SBC rear distributer is not bullet proof nor water proof; yet it seems no one complains when it needs a cap and rotor, gets wet due to a pressure washing and fails, or needs replacement due to wear.
The real problem is that the rear mounted SBC distributor's location makes a distributor change a simple and quick task, and in comparison the opti is an afternoon of wrenching.
Time to pressure wash my engine bay. Mike
I plan on putting an LT1 motor in a TPI car and using a distributor and the TPI wiring. Anyone ever do this?
