85 with dash problems
Old Jun 10, 2007 | 02:14 AM
zack3211's Avatar
zack3211
8th Gear
Default 85 with dash problems
When i start the car i can see the gauges but the do not iluminate. the blinkers and headlight lights on the dash stay on though. I hit the bottom of the dash once and got it working . It was working till a week ago. I thought it might be a short but cant find any. Can someone pls give me some advice?
Old Jun 10, 2007 | 02:18 AM
zack3211's Avatar
zack3211
8th Gear
does anyone think this could be the same as the 84 with dash?
Old Jun 10, 2007 | 02:19 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
It is a bad ground. If all the pins at the main plug are clean and it still does it, you'll have to dissect the instrument cluster. Even getting to the harness requires removing the cluster.
Old Jun 10, 2007 | 02:28 AM
zack3211's Avatar
zack3211
8th Gear
there i a grey wire cut under the dash. should i groud it?
Old Jun 10, 2007 | 02:29 AM
CentralCoaster
No.
Old Jun 10, 2007 | 03:12 AM
funder354's Avatar
funder354
This is a pretty easy fix - I just went through this repair.
http://www.corvettemagazine.com/1999...ash/dashp4.asp
You need to remove the lower dash cover - the ambient temperature overide switch is located under the left dash, (if memory serves me correctly) above the clutch. If you can't find it PM me tomorrow afternoon and Ill pull off my cover and email a picture of my repair job.
Old Jun 10, 2007 | 05:50 PM
zack3211's Avatar
zack3211
8th Gear
i grounded the black/white wire from the temp switch and it is still not comming on
thanks for the website
Old Jun 10, 2007 | 06:08 PM
rel3rd's Avatar
rel3rd
My 85 just lost the cluster's illumination when I hit a big bump the other day. No blinker or headlight indicators lit though...
Good Luck figuring it out. I'll be diving into mine one day soon as well.
Old Jun 11, 2007 | 12:25 AM
CentralCoaster
I tried that ambient temp fix on another car and that wasn't it either. I don't think that's the most common failure point, but it is easier to check.
Old Jun 11, 2007 | 12:32 AM
funder354's Avatar
funder354
First question: By grounding the wire did the turn signals and bright light indicator turn off?
If so then it sounds like you may need to remove the entire unit. This also is a pretty easy job. You will have to pull apart the unit and resoder the 12 pins that connect the two circuit boards. Its not to difficult to do. This web site should give you all the info that you need. If you have any questions let me know. I just went through all this 2 weeks ago. Good Luck.
http://www.batee.com/corvette/dcrg/repair.htm
the problem more than likely lies on this page...........
http://www.batee.com/corvette/dcrg/repairing_ip.htm
To 85 with dash problems
