Hood Drains
Old Jun 10, 2007 | 09:47 AM
Larry64's Avatar
Larry64
Default Hood Drains
How do you get the hood latch drain kit in around the blower fan on 90-96 models?
Old Jun 10, 2007 | 12:52 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
I used a right angle drill and drilled a hole on the outside back side if the latch. Did not use a kit, just get a can of spray paint and spray the hole to keep it from rusting, this way you do not have to worry about the blower.
Old Jun 11, 2007 | 09:05 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
On the passenger side, I drilled at the lowest point on the side facing the rear of the hood latch support per the instructions.
To Hood Drains
