Need help changing plug wires on 94 LT1
Old Jun 11, 2007 | 06:47 PM
lilspit1's Avatar
lilspit1
Default Need help changing plug wires on 94 LT1
I have changed all of the plugs on my 94 vette.
I managed to change the 4 wires on the passengr side.
However I stopped when I went to deal with the drivers side wires.
Can anyone tell me what I have to move or remove to be able to change the 4 wires on the drivrs side.
Unfortunately the Haynes repair manual does not describe this for the 94 LT1.
Old Jun 11, 2007 | 08:34 PM
Mojave's Avatar
Mojave
Take off the belt, belt tensioner, and remove the power steering pump. You don't need to loosen the lines or drain the system, just move it out of the way. This should give you the space needed to get the driver's side wires off.
Old Jun 11, 2007 | 08:36 PM
Atok's Avatar
Atok
I just changed mine a couple weeks back. Mine's a '95 but should be the same I would think:
1. Remove belt.
2. Remove belt tensioner. One bolt.
3. Remove bolts from power steering pump.
4. Rotate power steering pump forward a little to give more room to route the wires behind it.
That should give you enough room to get them changed. You can't get at the wires on the OPTI without removing the tensioner. After you remove it you'll see it's much easier.
Old Jun 12, 2007 | 08:35 AM
ken93vette's Avatar
ken93vette
Default Good Link for Changing Plugs Wires
Here is a link that was very helpful to me,
http://vettenet.org/lateplugs.html
Old Jun 12, 2007 | 11:10 PM
lilspit1's Avatar
lilspit1
Default Thanks.
Thanks Folks. I folowed the advice you gave and all the wires are now changed.
Old Jun 13, 2007 | 03:13 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
How long did it take you for both sides? I still need to change mine out. Did you have to jack up the car or remove any wheels?
Old Jun 14, 2007 | 02:29 PM
JCD's Avatar
JCD
I like to pull the wheels because it gets the car a little higher and with the wheels off I don't have to bend over so far. But I'm not a teenager anymore. Of course pulling the wheels takes away my favorite tool shelf.
Old Jun 18, 2007 | 08:51 AM
onedef92's Avatar
onedef92
Man, I wish you were closer to Louisville. I sure could use some help changing mine. I don't have a floor jack, plus my house is built on a hill, so I can't jack it up on my inclined driveway.
To Need help changing plug wires on 94 LT1
