Tv cable oil seal..
Old Jun 11, 2007 | 09:33 PM
86GoldProject's Avatar
86GoldProject
Default Tv cable oil seal..
I just bought a replacement TV cable and it has a different oil seal than the old one. The old one had a cylinder shaped seal that fit into the hole in the trans case and the cable than went in, the new one has a flat o-ring type seal at the top and thats it.. which one do I use? Or should I try to use both togather?
Old Jun 11, 2007 | 09:41 PM
Pete K's Avatar
Pete K
The correct type is called a boot seal. The o-ring is incorrect.
Old Jun 11, 2007 | 09:43 PM
86GoldProject
weird.. guess I need another TV cable..
Old Jun 11, 2007 | 09:47 PM
Pete K's Avatar
Pete K
I always use a gm replacement cable. If you bought an aftermarket cable, you may want to exchange it for the gm.
Old Jun 11, 2007 | 10:46 PM
86GoldProject
yeah, if I can't get the origional seal to work with the aftermarket cable looks like I'll be going that way.. thanks man!
To Tv cable oil seal..
