questions: opti & waterpump
Old Oct 25, 2001 | 08:48 PM
emoshn's Avatar
emoshn
Default questions: opti & waterpump
I'm thinking (!) about replacing my opti and waterpump (new wires plugs, etc.) all in one fell swoop. Seems like I read somewhere about how to replace the opti (tricks) and pump. But I can't find it under tech tips.
Anybody have a link or care to enlighten me BEFORE I begin this process?
Also, has anybody had any experience with the aftermarket electric waterpumps? I saw one in Jegs that looked pretty cool and wasn't any more money than a replacement pump.
Speaking of price, I'm thinking Paceparts...anybody know a better (cheaper) place to get parts. AND one more item: need info about putting the kit on the opti to make it better. I KNOW I've read it here, but can't find it. (There is one on tech tips...but it's not the one I remember...the one I know about had pics)
HELP
Thanks\
Dave Slater
dslater@polarnet.com
dslater@newsminer.com
Old Oct 25, 2001 | 09:22 PM
bogus's Avatar
bogus
Default Re: questions: opti & waterpump (emoshn)
first off, you need access to the feb 2001 issue of corvette fever. it outlines all the mods needed to update a pre 95 opti.
second, contact carfan18. he will fix you up.
I really don't know if they make an electric pump for the LT1.... I have yet to find one, but maybe I have'nt looked hard enough!!!
if you have any qx, please email. I have done this project... it is time consuming, but not hard. abbogus@yahoo.com
Old Oct 25, 2001 | 10:26 PM
emoshn's Avatar
emoshn
Default Re: questions: opti & waterpump (bogus)
Thanks Andy,
What I'm thinking is just removing everything from the front of the engine...all seems pretty straightforward except the a/c compressor. Pulling that and the alternator and anything else I can find, including the radiator hoses. It looks like that will open everything up quite a bit. I figure the waterpump change should be pretty straightforward, but I've never worked on the opti before and want to make sure I get it off and the new one on right the first time. Want to change plugs and wires at the same time. So any advice you can give on this project would be greatly appreciated.
dave
Old Oct 25, 2001 | 10:40 PM
OcalaGuy's Avatar
OcalaGuy
A few days ago someone was talking about installing a electric waterpump. It's called a Meziere elec water pump.
Here's a link to it....
http://www.racenet.net/missing.php3?...alvetrain.php3
Here's the forum link where they were talking about it
http://forums.corvetteforum.com/zerothread?id=171179
Hope this helps
Old Oct 26, 2001 | 12:03 AM
bogus's Avatar
bogus
you don't need to go that deep... removing the air intake will give you a TON of room.
I did'nt even have to remove the radiator. you just cannot use air tools, tho.
I have the issue in question - ment to say that - and can fax it to you. I need to get a scanner, then I can email the darned thing!
Old Oct 26, 2001 | 01:28 AM
JasonL's Avatar
JasonL
Try these links for some procedures on opti upgrades/replacement/etc
http://members.home.net/jreed012/optispark.html
http://www.houston-f-body.org/tech/optispark/
http://www.charm.net/~mchaney/optisprk/optisprk.htm
As mentioned above, you really only need to remove the air intake, coil, belt, and damper to get the opti off. No need to mess with the alternator or A/C unit.
[Modified by JasonL, 9:29 PM 10/25/2001]
Old Oct 26, 2001 | 10:28 PM
emoshn's Avatar
emoshn
Default Re: questions: opti & waterpump (JasonL)
Thanks jason....that info should REALLY help me out. I've printed out all three sites. And thanks to everyone...now I can rest a little easier knowing something.
Dave
Old Oct 26, 2001 | 10:29 PM
emoshn's Avatar
emoshn
Thanks Andy...I think I can do it, but I may get in touch.
Dave
To questions: opti & waterpump
