Another starting problem
Old Jun 12, 2007 | 05:50 PM
LannyL81's Avatar
LannyL81
Default Another starting problem
Friend's '87....has had starting problems in that the starter will not turn over. The VATS appears to be working fine...the starter enable relay is pulling in.
However this past weekend he took the starter solenoid wire off as part of his troubleshooting and found that there was +12V there when the key was OFF.
Anyone run into this problem before? He has replaced the ignition switch...(which doesn't mean that its good), but how in the world could there be +12V there unless the wiring has shorted (which I really doubt). He did find the clutch start safety switch was not making contact all the time...which is what I told him to check.
Thanks for any hints to pass along to him.
