relacing tranny filter 84
Old Jun 13, 2007 | 06:12 PM
timscott's Avatar
timscott
Default relacing tranny filter 84
Just want to know how hard of a job it is to change the filter and pan gasket on my 84 vette 700 R4.
Old Jun 14, 2007 | 11:19 PM
Miguy1957's Avatar
Miguy1957
Had mine done at a trans shop 20.85 for the filter and gasket 15.00 for the fluid and 25.00 labor. for 25.00 I dont think I would crawl under the car and deal with the mess. Just my thoughts.........
Old Jun 14, 2007 | 11:29 PM
Pete K's Avatar
Pete K
Not hard at all. 1 hrs work
Old Jun 15, 2007 | 12:10 AM
RRT vette's Avatar
RRT vette
Yep, fairly easy. Hardest part is jacking the car up where it is safe enough to get under it. Have something to catch the fluid in and unbolt the pan. Make sure you have a tranny pan gasket, filter, and fluid ready to go.
Old Jun 15, 2007 | 01:10 AM
timscott's Avatar
timscott
Thanks guys.I'm going to tackle it in the morning. I have the parts and fluid so I'm ready to go!
Any secrets on draining the fluid before pulling the pan off?
Old Jun 15, 2007 | 01:44 AM
RRT vette's Avatar
RRT vette
None that I am aware of. Once you start removing the pan bolts, be ready to catch the fluid.
Old Jun 15, 2007 | 01:52 AM
86GoldProject's Avatar
86GoldProject
dont take all the bolts out, take most of em out, leave maybe 2 on the front or back half way out, remove the ones on the opposite side and try to drain the pan as much as possible, than remove the remaining bolts. Not fool proof but its harder to make a mess that way
Old Jun 15, 2007 | 05:58 AM
Happydad's Avatar
Happydad
Don't wear a long sleeve shirt
Old Jun 15, 2007 | 07:08 AM
Pete K's Avatar
Pete K
I use a $10 siphon and suck the fluid out the dipstic tube.
Old Jun 15, 2007 | 07:09 AM
Pete K's Avatar
Pete K
Also, no sealant on the pan gasket and torque the pan bolts to
100 INCH pounds to prevent leaks.
Old Jun 15, 2007 | 07:59 AM
DonF's Avatar
DonF
Good idea on the siphon Pete I just make a mess that takes longer to clean up then changing the gasket. It is not hard at all using Pete K's idea will make it easier. Donf
Old Jun 15, 2007 | 11:05 AM
timscott's Avatar
timscott
Awesome idea! Thanks guys.
To relacing tranny filter 84
