I read somewhere that if you remove the vacuum line from the fuel pressure regulator and plug it, you will get better mileage and better acceleration. Myth or fact?
removing the vacuum line may work for you if you have a fuel delivery problem, by masking the problem by increasing the fuel pressure.
It doesn't hurt anything. If you had an adjustable fuel pressure regulator set at 45 normal, 47-50 with the vacuum line off, you would only more finely atomize the fuel droplets, and in essence, yes the mileage would increase.
As for performance, I think the injector optimum pressure is 47-49 PSI, and increasing past that point, would make the injector inefficient, and actually reduce volume.
Everything is a trade off. It just depends on what you reallly want. a 30 mpg corvette to get 32mpg? or a 30 mpg corvette to go faster quicker?
I have removed the vacuum line, and in 115 degree heat here in phoenix, it seems to run better, even if it is just a finer mist that equates to better internal fuel cooling.
Jeff at CAM in NC analyzed my scan data (high lean block number, no codes) and said that usually means a suspect fuel pump. Would this mod make it work easier? I'm trying to squeeze all the life I can out of since it's a hassle to replace.
...i won't address that at this point but, i would strongly urge you to replace the fuel pump asap before it leaves you stranded someplace.
...my pump at times would register a good pressure and at others would not until one day it left me in te driveway. replace the pump (about an hours work) and be done with it....
If you suspect fuel pump .... the last think i would do is to raise the fuel pressure removing the vacuum input.
The best mileage it's false. You will use more gas or the same gas as before if the computer (ECM) can compensate the added fuel reducing the BLM up to 108 . If you see 108 on the datalog you are using more gas than before even if the ECM on the dash istant MPG is saying less.
If BLM are above 108 you are using the same gas.
With the added fuel pressure the inj pulse widht will be less longer than before and the computer will say you are using less gas. (..but it's not true..)
-Beppe-
-Beppe-
Also from what I know, better atomization is good but not at the expense of being pig rich. This is why you size the injector correctly. Right size injector, right atomization, right fuel pressure. When you unplug the regulator it can no long change the fuel pressure at part throttle. This is what the full throttle fuel pressure is so you are running WOT pressure all the time. If you set your WOT fuel pressure super high you can gain atomization but get to rich.
I need to check with a fuel pressure gauge, but this is what we suspect: The ECM is over compensating for a weak pump causing the engine to run rich (high block learn number). Yes, I've changed the filter but the exhaust smells alot like raw gas. Thought maybe this mod would bring my fuel pressure up and make the engine run more efficiently. Also thought the vacuum might be part of the emmision control too.
So far, four nays and three yeas. Could it be a debate? The modders versus the stockers...
It's easy and cheap to check the FP. Tape a gauge to the window and do a few WOT runs, try to get high RPM. If the FP falls off at all from where it is set, there is a problem. Have you checked the vacuum line at the regulator for gas? It could be a problem with the regulator to. If the pump is going bad it could totally quit, leaving you stranded.
Being super rich can damage the cats. It could be from a leaking injector, there are a number of things it could be. Get a FP gauge. Also see if the FP leaks down with the gauge.
The regulator is used to increase fuel pressure when the manifold vacuum decreases as when you push down on the gas pedal. You have no vacuum to the regulator at wide open throttle so it will not change anything at that point. It will only increase pressure at idle and low throttle. It might make it idle and cruise better if you are running lean now, but will not make more power when you put the pedal to the floor.
