89-96 RIpper shifter
Old Oct 26, 2001 | 11:19 AM
snaketr's Avatar
snaketr
Default 89-96 RIpper shifter
Who has installed one in a 89-94? Does this shifter eliminate the manual reverse lockout? There is not enough romm on the shifter for my manual lockout and my shifter ****. There is also no hold through the handle for the little pin in the reverse lockout. Please help.
Old Oct 26, 2001 | 03:18 PM
Justin Scherer's Avatar
Justin Scherer
Default Re: 89-96 RIpper shifter (snaketr)
The Ripper does not have a reverse lockout mechanism. Its only got a spring with a little **** that makes it a little harder to slide the gate over into reverse. Its not even worth installing. Basically, there is no reverse lockout.
Here is some of the pain I went through. It may help: http://www.snowdirt.com/corvetteshifter.html
Justin
Old Oct 27, 2001 | 06:56 AM
rnelson11's Avatar
rnelson11
I bought the B&M model 45056 for my '95. It included a hole through the handle and a pin with spring for cars with reverse lockout.
Old Oct 27, 2001 | 10:46 PM
CELT4's Avatar
CELT4
Default Re: 89-96 RIpper shifter (Justin Scherer)
Excellent write up, Justin. I think I will go with a Hurst.
Old Oct 29, 2001 | 03:48 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: 89-96 RIpper shifter (CELT4)
I have the Ripper and would not give it up....period. Some don't like it, to me it is a necessity.
Old Oct 30, 2001 | 03:37 PM
zrchris's Avatar
zrchris
If you want to see a true comparison between the units, read this document:
http://www.prism.gatech.edu/~gt1479b/C4shift.doc
Old Oct 30, 2001 | 08:34 PM
RichS's Avatar
RichS
Default Re: (zrchris)
I'm very happy with my Ripper. Tried the Hurst in another car and still rather my Ripper.
[Modified by RichS, 7:35 PM 10/30/2001]
To 89-96 RIpper shifter
