I seem to have the best results N/A with a 12.5:1 A/F ratio at heavy - WOT. I know most nitrous cars like the A/F ratio at about 12:1 or sometimes a little richer.
Ray Bohacz wrote :The term "stoichometric" identifies the ratio offering the most complete burn. For unleaded gasoline, it is 14.67:1, which is commonly rounded to 14.7:1. The stochiometric value for other fuels varies with their energy content, but our discussion will be limited to the requirements of gasoline.
Ok, this is theory, but in reality what is really working for you guys, and how are you measuring this?
Measured with wbO2. I like to run mine at 11.8 through about 12 psi and then I gradually drop to 11.4 up to the mid 20s. High vacuum to WOT, no boost, ranges from 14.6 to 12.9 A/F.
You can only run the 14.xx stoichiometric A/F ratios on light acceleration or cruise. Running a stoichiometric A/F ratio under heavier acceleration could cause drivability problems. Most N/A cars need an A/F ratio richer than that for power production, usually between 12.5-12.8:1. A/F on boosted cars should be richer than that, like 11.5:1. You can measure A/F ratios accurately using a wideband O2 sensor. They are expensive, >$1,000, but very necessary for tuning the A/F ratio at different rpms and loads.
There are in dash wide band gauge kits for $300ish now. I saw a used wide band o2 for pretty cheap in the for sale section recently.
I put this autometer wideband gauge in my 68 Camaro a couple weeks ago, cost was $350 from Summit for the complete kit. It has an output for a datalogger or PCM hookup. Not sure where one would put something like that in a C4 tho.
Do you hook it up to the O2 sensor, or is there a special place that you have to conect the sensor to give a readout?
In the camaro, I just drilled a hole in one of the collectors, zapped the bung in with the mig, and screwed the sensor in.
The guage I bought (and most others I know of) comes with the proper sensor, which is different than the ones that our in our vette's, those are narrow band.
