Why do C4's eat alternators?
Im assuming you have the older smaller unit that wears out all the time.
About the upgrade,someone should post it.Its been done before.
I guess sometimes you get lucky and have one that will just keep going.
I have a 95 olds Van,3800 V6 engine with the CS144 in it...it made some bearing noise one day and I had a shop install new bearings and test everything out...I had 140K on it..they fixed it,and said the internals were good and now have nearly 180K on it...Im a believer sometimes we get good parts,but also that the 144 is far superior than the 130 units.
not all parts are created equal... I think most aftermarket C4 alts are JUNK!
On my TownCar, after replacing the "Lifetime" warranty piece of junk for the 4th time in 2 years, I bought a new one and didn't replace it the remaining 5 years I owned the car.
It cost twice as much but was well worth it.
I have had good luck with local rebuilds too, where they use quality components.
But, the "chain store" "lifetime warranty" garbage has diodes made in a camel tent in the middle of the desert by a woman in conjunction with doing her laundry.
Impurities in diodes and other silicon components cause gradual degradation over time and with heat
Diodes need to be made in a "clean room" environment, and "cost cutting" demanded by the consumer today (you get what you pay for) has driven the diode production to third-world countries that couldn't care if they last -- but, you get a lifetime warranty.
You say you want a "real" alternator?
Hold onto your wallet:
http://www.mean-green.com/products/alternator.html
Notice it has a one year warranty like most quality units do.
However, I also had good luck with the Autozone Duralast Gold (brand new) alternator that does have a lifetime warranty. But, it costs twice as much as the rebuilts that Autozone sells.
Tom Piper
Open your hood after a drive and try to place your hand on the alternator. You will see quickly why its dying.
Do all of the above and this will end your alternator purchases.
John
My success has been adding ground straps in front and behind the alternator. Havn't had a problem since.
Although I may have gotten lucky with a quality rebuild, but you never know.
