Lt4 Valve Springs
Old Jun 18, 2007 | 04:49 PM
lefoy84's Avatar
lefoy84
Default Lt4 Valve Springs
I am looking at swapping the cam in my Lt4. If I put in a Hotcam and stick with 1.6 rockers what springs would you all recommend?
Old Jun 18, 2007 | 05:34 PM
etown brawler's Avatar
etown brawler
put in the g.m.p.p hot cam1.32 inch springs and light weight retainers and keepers ,they are matched for the cam .i have b/n lt4 hot cam springs ,retainers ,keepers,spring seats,these are used under the spring because stock is 1.25 and these springs are 1.32 inch .i bought all of these from g.m will give you for a good deal if you want them .didnt end up using my stock heads they are b/n in boxes/bags
Old Jun 19, 2007 | 10:46 AM
lefoy84's Avatar
lefoy84
Do you have part numbers for these?
Old Jun 19, 2007 | 11:16 AM
Aardwolf's Avatar
Aardwolf
Maybe this will help:
http://www.superchevyperformance.com...p/12495494.htm
Old Jun 19, 2007 | 12:52 PM
STL94LT1's Avatar
STL94LT1
Check out the Crane H-11 tool steel springs, they are a direct drop in for the LT4. Or if you want to spend a little more money get the Comp Cams 918's.
To Lt4 Valve Springs
