No Power To Fuel Pump
Old Jun 18, 2007 | 07:44 PM
secrt0007agt's Avatar
secrt0007agt
St. Jude Donor '15
Default No Power To Fuel Pump
My 93 LT1 will not start & it appears that I am not getting any power back at the fuel pump. I pulled the power plug, turned the ignition on, but no sound (when plugged in) & no power coming from up front. I checked all fuses & replaced the relay. ???? Damn thing was working the other day!
Old Jun 18, 2007 | 08:07 PM
CFI-EFI's Avatar
CFI-EFI
Is there power to the relay contacts (secondary side)? Is the ECM energizing the primary side of relay for the 2 second priming period? You can run 12 volts to terminal "G" of your ALDL and/or the power plug at the tank to verify that the pump still works.
RACE ON!!!
