6-Speed Launching
Old Jun 20, 2007 | 08:17 AM
mn_vette's Avatar
mn_vette
Default 6-Speed Launching
Hey guys,
I've done the search and I'm still looking for good tips or expected times for a decent 6-speed launch on street tires.
I'm running a set of 315 BFG's and I have the stock 3.45:1 gear ratio.
I've been doing 1500rpm launches letting out the clutch and I seem to be getting right around 2.0 for my 60'.
Should I be getting better? It seems to bog or spin I can't seem to find the sweet spot in the middle. Any suggestions? I'm heading back to the track this afternoon. Thanks.
Old Jun 20, 2007 | 08:29 AM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
On street tires, the best I could get with my old set up was around the 2.0x range. A soft compound tire will help shave a tenth or two, and you can launch more aggressively at a higher RPM.
With your combo and street tires, I think a 2.0x is about right.
Old Jun 20, 2007 | 09:21 AM
JCD's Avatar
JCD
sounds like you have the idea correct, unless your car is down on power you're doing all you can. A little wheelspin is better than a bog.
Old Jun 20, 2007 | 12:13 PM
mn_vette's Avatar
mn_vette
I'm running a turbocharged 383 so it takes until the top of first gear to get the thing spooled. But I shouldn't be low on launching power with the stroker.
Old Jun 20, 2007 | 12:26 PM
STL94LT1's Avatar
STL94LT1
I was able to get a 1.86 60' with my Kuhmo MX's. I launch off idle, and roll into the throttle as a let out the clutch.
Old Jun 20, 2007 | 12:37 PM
mn_vette's Avatar
mn_vette
Was that with the 4.10's? I've heard that those really help out the 60' time.
I'd love to upgrade but I'm trapping almost 130mph now and it should be going up soon.
Old Jun 20, 2007 | 12:42 PM
STL94LT1's Avatar
STL94LT1
Yes, it was with 4.10's. Sorry I forgot to mention that. The 4.10's will also help a lower rpm launch without a bog. But, they are way too much gear for your engine.
To 6-Speed Launching
