C - Beam Installation Question???
Old Jun 20, 2007 | 03:33 PM
Steel Breeze's Avatar
Steel Breeze
Default C - Beam Installation Question???
Here is another one on the C- Beam. If I remember right, I couldn't take the C-Beam out until the rear end was loose. So anyone with knowledge on this, please speak up. Can the chunk inc. bat wing, and driveline be installed, and the C-Beam put in last, Or is there a certain technique or order of installation??? I'm appreciating the help men...
Old Jun 20, 2007 | 03:43 PM
85vet's Avatar
85vet
Cruise-In V Veteran
The last time I put the C-beam in seperately it was a pia. When I reinstalled my differential, I had the C beam bolted loosely up to the tranny and the tranny lowered a bit to drop the back of the C-beam. Remember to pull the distributor cap.
The differential went in fairly easy on a jack. I angled it to be in the C-beam & jacked the differential & the tranny slowly and it went in easier than I expected.
Good luck!!!!
Old Jun 20, 2007 | 03:47 PM
Steel Breeze
Thanks, that was what I had planned, but I was hoping there was an easier way. I'll have to keep my eye on that dist. that is an easy thing to forget.
Old Jun 20, 2007 | 06:01 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
You should be able to put the C-beam up in there w/o bolting it in, install the drive shaft and then bolt the beam in place. Works for me, anyway.
Old Jun 20, 2007 | 07:12 PM
Strick's Avatar
Strick
It sure is easier with beam plates.
Old Jun 20, 2007 | 07:15 PM
SouthernSon's Avatar
SouthernSon
Shove forward end in first, then work toward the rear end.
Old Jun 20, 2007 | 09:31 PM
edoad's Avatar
edoad
I managed to get it in seperatly, third member in place, by lowering the transmision and pushing it to one side. Shouting a few epitaphs helps. Put in drive shaft before bolting the C beam in place. Most important Have Fun
Old Jun 20, 2007 | 10:50 PM
aboatguy's Avatar
aboatguy
To C - Beam Installation Question???
