Coolant in Oil AGAIN! Rant/Help
Old Jun 21, 2007 | 01:07 PM
rap87's Avatar
rap87
Default Coolant in Oil AGAIN! Rant/Help
Just some background, my first car buying experience and vette experience is turning out to be the worst nightmare of my life. I bought this car from premier auto auctions in WI, over the internet from auto trader.com. I paid about 15k for a 96 corvette with 64k on it. Since I have gotten it I've had to put 4 new tires on it, a new optispark, and rebuild the tranny. I have logged prolly 600 miles on the car and it of course blew a head gasket. I've been working on the head gasket for the past 2 months finally get it all back together and it starts smoking again. Coolant seems to be coming from the driver side head from the exhaust. And my oil level went up with antifreeze in it...I'm at a f'in loss here...I had the heads skimmed and compression tested, used a torque wrench, used the book, permatex the threads...all the crap I can think of to do it right and here I am $500 more dollars short and no where near ready to go...Could use some advice or what the heck I can do....I just don't have any more money to throw at this thing...I feel like I'm going to end up paying 350 bucks a month for the next 5 years for nothing...I sure wish I knew about this place before I bought my vette off the internet.....
Old Jun 21, 2007 | 02:12 PM
Chatman's Avatar
Chatman
I am very sorry to hear about this outcome. You deserved better.
How quickly did this leak appear after your repair?
Did you do only one head before? This one I was included I assume?
Was it clear from your tear down that it was a gasket failure before or could there be a cracked head?
The good news is that you will make the repair this time in less than 1/2 the time.
Old Jun 21, 2007 | 02:20 PM
rap87's Avatar
rap87
1. It started very quickly, on the second start up since I finished. I took it around the block, brought it back, started it the next day and found the problem.
2. I did both heads at the same time.
3.It wasn't very clear that it was the gasket, to me at least, however, I brought the heads to the shop and my heads were warped.
Old Jun 21, 2007 | 03:19 PM
jfb's Avatar
jfb
You might have a cracked block causing the coolant leak into the oil. I also recommend that you use Felpro teflon coated head gaskets, they last much longer than non teflon coated gaskets. Regular gaskets never lasted more than 1 1/2 yrs on my 87 until I used the teflon Felpro's.
Old Jun 21, 2007 | 03:37 PM
rap87's Avatar
rap87
I used the Felpro kit from Autozone...Blue colored top. How would I find if the block is cracked...
Old Jun 21, 2007 | 03:41 PM
jfb's Avatar
jfb
If you cannot see an obvious crack, then the block has to be Zygloed.
This is a process where a dye is sprayed onto the block and removed and the dye stays in cracks and can be seen with a blacklight. Not easy to do, but a lot cheaper than replacing head gaskets everyday!
I would first have the heads checked with Zyglo to see if they have a crack.
Old Jun 21, 2007 | 03:59 PM
rap87's Avatar
rap87
I noticed as well that all the plugs on the passenger side were kinda sooty/normal, where all the plugs on the drivers side looked white and new...would that indicate, as well only one side is screwing up?
Old Jun 21, 2007 | 04:37 PM
cv67's Avatar
cv67
St. Jude Donor '05
Ouch, that bites! Did they check for cracks in the head (between the valves)? Is your intake manifold sealed real good?
Old Jun 21, 2007 | 05:20 PM
staugur's Avatar
staugur
What do you mean when you say "coolant appears to be coming from drivers side head exhaust"? Can you see water coming out from between the head and the block?Could be cracked block,head,inlet manifold.Dye test would seem to be the answer but it seems it has to come apart again unless it's something really stupid.If that's a 383 have the heads been badly ported?Nice clean plugs could indicate water in all four cylinders which would push me in the direction of the inlet manifold.
Old Jun 21, 2007 | 10:15 PM
rap87's Avatar
rap87
I didn't have the headers connected to the collectors 100%, and I could see the coolant squirting out of the side of the headers. I can not see water coming out from the head and block. As far as the 383 question I only knew it was a 383 by measuring from the top of the head to the top of the block and it measure more than a stock 350 would, which would indicate it had been bored out. What would be the inlet manifold?
Old Jun 21, 2007 | 10:51 PM
Dan Parker '96's Avatar
Dan Parker '96
I bought mine off the internet. Never a problem.
A head gasket problem is severe. You probably have a moron engine builder that is assembling your stuff.
A head gasket problem is pretty much very low priority in the realm of small block GM. Shoot your assembler.
Old Jun 21, 2007 | 11:31 PM
mseven's Avatar
mseven
Regardless hind sight is 20/20 ....there would of been no way to predict headgasket failure. Tires etc. is realatively normal.
The first thing I would do is to make sure it isn't coming from the inatke.
Before you actually pulled the heads how much was it leaking ? where? Did the gaskets match up properly to the water jackets etc.? What method did you use to torque the head bolts down? As to being able to use dye to find the problem, the motor would need to be running, and from what you describe if it is pouring out like that you won't be running it now. I think if it is flooding everything outside like that, you should be able to see something. You will have to inspect the block, the freeze plugs et. all carefully.
Old Jun 22, 2007 | 02:14 AM
cv67's Avatar
cv67
St. Jude Donor '05
The only way to know if its stroked or not Is to pull the pan check for a notched block or pull the heads and measure how far down in the bore the piston goes. Otherwise you cant tell what it is.
Old Jun 22, 2007 | 07:57 AM
rap87's Avatar
rap87
How am I able to check to see if its coming from the Intake? I used gaskets and RV Sealed it down...where does coolant circulate through the intake to cause that? I torqued the heads down first to 22, then to 45, then to 60/65 bottom/top. I used the tightening sequence in the Haynes manual.
rap87's Avatar
rap87
I guess thats what I mean, I measured how far down in the bore the piston went from bottom to top.
Old Jun 22, 2007 | 08:25 AM
rap87's Avatar
rap87
Well the way this thing was advertised I pretty much feel it was sold on the internet on purpose. When it rolled off the flatbed it had a dead battery, auto trans was slipping, no tread on the tires, and the opti apparently was taking a crap all at the same time. Oh yeah and the fuel pressure was set at like freakin 20, so you had a hard time starting it.
As far as the engine builder I don't know who the hell it is.
Old Jun 22, 2007 | 08:41 AM
rap87's Avatar
rap87
Just doing some thinking, but as far as in the intake, how does it work in terms of coolant. I put RV sealant on the back of the gasket and put it down on the heads. Then I put rv sealant on the back and front of the block itself. Then I put the intake down and tightened all the bolts. How would you go wrong on that...However, if lets just say one bolt happened to fail on the head itself it doesn't make sense that all 4 cylinders would have coolant in it making clean plugs...you would think it would only show up on one or something....
To Coolant in Oil AGAIN! Rant/Help
Old Jun 22, 2007 | 09:26 AM
rap87's Avatar
rap87
Well, from doing some googling, it seems that the LT1, doesn't run coolant through the intake manifold, so I guess its back to how the hell could the block and the head not seal...
Old Jun 22, 2007 | 10:35 AM
Hooked on Vettes's Avatar
Hooked on Vettes
Is it possible you installed the driver side head gasket upside down?
Old Jun 22, 2007 | 10:52 AM
rap87's Avatar
rap87
Nope, they are both blue when facing up and identical gaskets...**** anyone in near va beach, va that might help troubleshoot this with me? Im just at a loss, I mean I did exactly everything identical on both sides and the passenger side isn't leaking...The only thing different on the drivers side is I had to install a heli coil on the drivers side right medium size bolt hole, but it did torque to spec with no problems...
