ABS bleeding
Old Oct 27, 2001 | 03:08 PM
dt35th's Avatar
dt35th
Default ABS bleeding
I need to replace the ABS valve on my 88. Is there a procedure to go through like when replaceing the master cylinder to bleed it or can I connect it and bleed the brakes as normal. Thanks
Old Oct 27, 2001 | 08:03 PM
dt35th's Avatar
dt35th
Default Re: ABS bleeding (dt35th)
ttt
Old Oct 29, 2001 | 09:40 PM
jcazin's Avatar
jcazin
if you have the master cylinder off, you'll need to bench bleed it to save a LOT of time and fluid- just run two pieces of rubber from the lines back into the res, and pump it till the bubbles are gone. Then hook it up and bleed your brakes- I bot a set of Russell Speed Bleed zerks, they work great
To ABS bleeding
