belt squeel?
Old Jun 24, 2007 | 06:55 PM
wpg92's Avatar
wpg92
Navigator
Default belt squeel?
I got my 92 back from the garage after just having wires put on (I know
I should be doing that myself) and now I have a loud squeel when engine revs up just before shift. I'm wondering what the most likely cause is - belt too tight, too loose, pully noise, belt not tracking? Is there abything else these jokers could've screwed up?
Old Jun 24, 2007 | 07:04 PM
CFI-EFI's Avatar
CFI-EFI
Either the belt is too loose or the shop lubed for for you. Check to see if they spilled some oil or grease on the belt or one of the pulleys. If not check your tensioner.
RACE ON!!!
Old Jun 24, 2007 | 07:14 PM
wpg92's Avatar
wpg92
Navigator
Thanks CFI-EFI, I'll check for grease on belt. Is it possible though belt
too tight and stressing a bearing? I don't know the proper tension.
Old Jun 24, 2007 | 07:32 PM
rcr103's Avatar
rcr103
The tensioner should keep it right
Old Jun 24, 2007 | 07:35 PM
CFI-EFI's Avatar
CFI-EFI
I guess. Not normally. A serpentine belt really can't get too tight. The tension is provided by the belt tensioner, which only weakens with age. A worn out bearing still could be making the noise. You will have to determine what is squealing.
RACE ON!!!
Old Jun 24, 2007 | 08:04 PM
wpg92's Avatar
wpg92
Navigator
Yes, I guess I wasn't thinking, the tensioner will keep it right. I guess I
was asking for some quick tips out of laziness and not isolating the noise first. The only problem is I have to get someone else to rev it up
as it is only at higher rpm. Thanks a bunch.
Old Jun 24, 2007 | 08:07 PM
bogus's Avatar
bogus
you can rev it yourself... grab the old throttle butterfly and let rip...
Old Jun 24, 2007 | 08:19 PM
wpg92's Avatar
wpg92
Navigator
Once again I'm typing before thinking. thanks
Old Jun 25, 2007 | 08:54 PM
wpg92's Avatar
wpg92
Navigator
Rev'd her up and no squeel, uh oh. Can you think of anything obvious
(tranny?) that the garage could've screwed up to make it squeel in
drive?
Old Jun 25, 2007 | 10:58 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default Power Steering?
Start the car and then turn the steering wheel lock to lock and see what it sounds like... If it makes unnatural noises then you will know... Power steering pump. If not move onto the next possivble problem...
To belt squeel?
