Need to know facts about NPTF thread ...
Old Jun 26, 2007 | 07:14 AM
Eike's Avatar
Eike
Default Need to know facts about NPTF thread ...
I have an oil cooler from Summitracing and want to make my own adapter for the filter. The thread for the hoses is 1/2-14 NPTF (dryseal, outer diameter 21 mm)
I need to know three things:
1. Are both, internal and external screw thread conical?
2. What's the correct bore diameter before tapping the 1/2-14 thread?
3. What's the correct bore diameter before tapping a cylindric 13/16-16 (oil filter) thread?
Best wishes from Germany
Eike
Old Jun 26, 2007 | 08:52 AM
rodj's Avatar
rodj
Drill chart
http://academic.evergreen.edu/projec...abric/pipe.htm
No listings for 13/16
"Are both, internal and external screw thread conical?"
Not certain what you mean here.
If reducing NPT to NPT, both the inner and outer threads of the reducer are tapered.
Old Jun 26, 2007 | 09:04 AM
l1sikes's Avatar
l1sikes
1. Both male and female NPT (National Pipe Thread) threads are tapered.
2. Use a 45/64" drill prior to tapping a female 1/2"-14 NPT thread.
3. 13/16" is not a standard ASTM thread diameter in either course or fine series. I suggest you re-check the thread measurement, it may be metric. If in fact it is 13/16", it is a special and you may have to fabricate your adaptor by salvaging the male part from a filter adaptor off of an engine , or the female part from a mounting plate out of a filter.
Good luck with your project.
Old Jun 26, 2007 | 09:11 AM
rons85's Avatar
rons85
13/16-16 is a straight UN thread. The minimum minor diameter (or minimum drill/bore size) for an Internal 13/16-16 is .745" or 18.9mm. A 19.0 mm drill would be fine to use.
As stated above - both male and female (external and internal) NPT threads are Tapered or conical. There is an equivalent Straight "pipe" thread standard called NPSM with the same basic diameters and thread pitches.
The 45/64" drill size for female 1/2" NPT thread is essentially the same as an 18.0 mm drill.
Normally, lines and fittings for an external oil cooler would use AN (37° flare) connections. The correct adapters for the cooler itself would be male NPT x Male AN, probably in a -8 or -10 size, depending on the hose diameter you wanted to use. These AN fittings and adapters are available from Summit, Jegs or many other sources.
Old Jun 26, 2007 | 09:24 AM
Eike's Avatar
Eike
Thanks a lot that does help
Eike
Old Jul 2, 2007 | 11:49 AM
l1sikes's Avatar
l1sikes
Hello Ron85,
Where did you find a listing for the 13/16 -16 thread ? My Machinery's Handbook did not show that size in UNC or UNF.
To Need to know facts about NPTF thread ...
