Now its a DTC 41
Old Jun 26, 2007 | 10:56 PM
Bob07's Avatar
Bob07
Default Now its a DTC 41
Could someone please help? Two weeks ago while driving my 93 the engine suddenly died and would not start back up. I pulled a code dtc 42 and was able to use the diagnostic chart from the FSM to determine that the Ignition Control Module was bad. I replaced the module and everything was ok. Now this past weekend I had the car out for a ride and it suddenly shut off again right after service ASR light came on, but this time it restarted with no problem and I was able to make it home. Checked the codes this time and got a dtc 41, I used the chart and traced it to an “Open Ignition Coil Module Ground Circuit”. What does this mean? How do you fix this?
Old Jun 29, 2007 | 11:32 AM
camarozz's Avatar
camarozz
I would say the module is prolly bad. Did you put the Heat sync gel underneath it?
Old Jun 29, 2007 | 12:43 PM
Bob07's Avatar
Bob07
Yes, I used all of the heat sync grease that came with the module
To Now its a DTC 41
