Tire choice.
Old Jun 28, 2007 | 03:57 PM
Aardwolf's Avatar
Aardwolf
Default Tire choice.
I am looking at two tires and trying to decide. Any suggestions? Other brands?
Kumho MX 275/35/18 (no 285 size) $205
Goodyear GS-D3 285/35/18 $265 plus $50 cash back card deal on four.
I like that the GSD3 is, wider, higher tread wear, more tread depth, and is made in America. I don't like that it weights a lot more, and it costs more but not bad.
Links to the tire specs:
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
These are for street use plus drag and road course. I would like to have a spare set of wheels with track tires but it's not going to happen for a long time.
Old Jun 28, 2007 | 04:00 PM
STL94LT1's Avatar
STL94LT1
I've been pleased with my MX's.
Old Jun 28, 2007 | 04:05 PM
JEFNLSA's Avatar
JEFNLSA
I wish they made them in a 315/35/17.
Old Jun 28, 2007 | 04:14 PM
Aardwolf's Avatar
Aardwolf
I had some MX 285/40/17 on my stock wheels and liked them. They were good on the street and track, but the GSD3 is probably better?
Old Jun 28, 2007 | 04:19 PM
BMF-LT1's Avatar
BMF-LT1
I have a set of 4 - 275/40 17 Yoko ES100 that I bought as a back-up set, and since have decided to move to a larger rim. They are brand new w/ stickers still on them.
If you're interested let me know, I sure we could work something out.
edit: sorry just realized you too had the desire to move up to an 18" rim.
Old Jun 28, 2007 | 04:22 PM
Aardwolf's Avatar
Aardwolf
Thanks for the offer but I switched to 18" wheels to clear the C5 brakes.
Old Jun 28, 2007 | 04:27 PM
Shimy86's Avatar
Shimy86
I've got the Goodyears and I LOVE them!!! They hook up like crazy
Old Jun 28, 2007 | 08:40 PM
90Z51's Avatar
90Z51
I've never used the GSD3, but I've heard from people that they don't handle heat real well. They seem to start chunking if they're driven hard for an extended period (like at a track day.) The Kumho MX is a proven performance tire, and while I'd definately take the GSD3 if I were only driving on the street, I think I'd give up a little treadwear and wet grip and just go with the Kumhos for your application. They're also considerably cheaper than the GSD3.
If you want to spend a little more than the Kumho, but still less than the GSD3 you should consider the Falken Azenis RT-615. It's only a 275, but the tread width is actually wider than the 285 GSD3. It's stickier and stiffer than the Kumho MX and GSD3 too. It's also lighter than the GSD3. If I were only driving on the street, I'd pick the GSD3 out of the 3 tires I've discussed. If I were driving street/track, I'd take the Falkens hands down.
Old Jun 29, 2007 | 12:13 AM
ScaryFast's Avatar
ScaryFast
I've heard a lot of positive results about the MX's but have never used them.
For another cheap tire look into the Goodrich KDW's. I run them on the M3 and they're fine on the street and decent on the track. They handle the heat well and don't show much abnormal wear after hard driving. They do show some "rippling" along the tread edge, but they do not chunk or come apart. They do get soft, however...
Since cost is a factor, I suggest getting some R compound scrubs. I have stacks of them that I run anytime I'm on track and not competing. I keep the new Hoosiers for the timed laps and run scrubs the other 60% of the time. Contact Bob at usdrctrs@aol.com. He has Hoosiers, Kumhos, etc. in any size you need. Expect to pay between $50-70 each (plus shipping) depending on brand and condition.
They'll last you a heck of a lot longer than new street tires. You'll need rims, but there are old rims all over the FS section for $400 a set.
4 scrubs @ $70e plus a set of rims for $500 = about $800, less than a set of new street tires...
Old Jun 29, 2007 | 12:18 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Most 17" wheels will clear them just fine.
Old Jun 29, 2007 | 03:41 AM
ScaryFast's Avatar
ScaryFast
I'm curious - where is the clearance an issue, offset or backspacing?
I assume the inside diameter of a 17" rim is plenty large. I have Brembo 4-pistons up front and run 17" A-mold rims. Backspacing is a concern for me but not diameter.
Old Jun 29, 2007 | 09:41 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
II like that the GSD3 is, wider, higher tread wear, more tread depth, and is made in America. I don't like that it weights a lot more, and it costs more but not bad.
The higher treadwear and increased tread depth on the GY's will hurt you on the race track. In that respect, I'd go with the Kumhos. The width difference is so small that it can be ignored.
I have the Kumho MX on my C4. I believe the Goodyears would be a better street tire, for several reasons that I won't go into here.
So, it comes down (in my opinion) to this:
For mostly street: go Goodyear
For mostly track: go Kumho
Anything else??
Larry
code5coupe
__________
not easily impressed....
Old Jun 29, 2007 | 09:48 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
I have the GS-D3's and have been very happy with them but it's my understanding they are made in Goodyear's Plant in Germany FWIW.
Old Jun 29, 2007 | 11:27 AM
CentralCoaster
4-pistons take up more space due to having pistons outboard of the caliper.
The Y2k wheels will probably clear Brembos with no spacers, they clear my wilwoods.
I'd really like to stuff some wilwoods under my 16" stock wheels for a nice sleeper effect, but there's about 1/4" not enough radius in there. I may try sawblades or cuisinarts though with some spacers.
Old Jul 1, 2007 | 01:12 AM
arkangel81's Avatar
arkangel81
my new sumitomos htrz2's rock compared to the falcon z radials i was running
Old Jul 1, 2007 | 10:22 AM
Aardwolf's Avatar
Aardwolf
Will my stock 17" '88 wheels clear? I didn't think to try it.
Old Jul 1, 2007 | 10:23 AM
Aardwolf's Avatar
Aardwolf
I went and looked at the tires I have in the shop, The Goodyears say Made in USA, and oddly the KDW do as well.
To Tire choice.
Old Jul 1, 2007 | 10:25 AM
Aardwolf's Avatar
Aardwolf
I thought of running scrubs but I do drive some street miles, and do see rain. The Kumho is looking like the best choice here till I get an extra set of rims, or if my stockers fit.
Old Jul 1, 2007 | 10:28 AM
CentralCoaster
Since you already bought 18s, no, don't try it. Just don't tell people you need 18s to clear them. Keep in mind the C5 had 17" front wheels.
Old Jul 1, 2007 | 10:30 AM
CentralCoaster
This particular tire model is made exclusively in the USA as far as I know, and the sidewalls I've seen.
But Goodyear has other models made around the globe and in South America. It's akin to buying a Toyota Tundra because it's MADE IN U.S.A.
