Are These LT1 Vette Heads??
Old Jun 28, 2007 | 05:53 PM
JAKE's Avatar
JAKE
Default Are These LT1 Vette Heads??
How can I tell if a set of aluminum heads installed on a 96 LT1 Vette are actually Vette heads and not 'F' body, etc.?
I plan to sell the LT1 engine I just pulled from my 96 and don't want to advertise something that isn't correct.
Jake
Old Jun 28, 2007 | 06:09 PM
Mojave's Avatar
Mojave
I'm pretty sure the heads are the same for an f-body and C4 LT1.
Old Jun 28, 2007 | 06:35 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
There are I believe three different part numbers over the years for aluminum LT1 heads. But none are Vette specific.
Old Jun 28, 2007 | 06:36 PM
JAKE's Avatar
JAKE
Then maybe it's the casting numbers. I recall reading that certain heads are more desirable than others.
Some of the head porters will port a set of heads on an exchange basis, but want certain heads with certain casting numbers.
Can you shed any light on that?
Thanks,
Jake
Old Jun 28, 2007 | 06:42 PM
Corvette Kid
Thanks,
Jake
Casting numbers are actually what I was referring to. Had I said that, I'd have been more correct. There is one casting number that does not allow as much grinding when porting. I believe it's the earliest ones though. Your '96s should be one of the two better ones.
Old Jun 28, 2007 | 06:47 PM
JAKE's Avatar
JAKE
Thanks for the responses.
Now if I can only figure out where the LT1 steam vent tube connects to the TB I'll be a Happy Camper.
My TB has so many places to connect hoses I wonder what in the HE** GM was thinking.
Jake
Old Jun 28, 2007 | 10:57 PM
aboatguy's Avatar
aboatguy
Thanks,
Jake
If you have 10207643 or 10128374 you've have the desireable ones from a porting perspective.
Mike
Old Jun 28, 2007 | 11:10 PM
Demonic85's Avatar
Demonic85
I found out that the casting numbers dont mean a whole lot when it comes to being vehicle specific when I got new heads.
Old Jun 28, 2007 | 11:34 PM
JAKE's Avatar
JAKE
Mike
Thanks for those numbers, Mike.
Jake
Old Jun 28, 2007 | 11:35 PM
aboatguy's Avatar
aboatguy
Jake
No problem! ....and as stated the Y and F body LT1 heads are the same. Good luck on the sale.
To Are These LT1 Vette Heads??
