warning light message LTPWS
Old Jun 29, 2007 | 10:00 AM
guywade's Avatar
guywade
Default warning light message LTPWS
what is ltpws lo tire pressure warning sensor ?? is that correct can someone answer right away thanks in advance
Old Jun 29, 2007 | 10:23 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
It's a warning that you have less than 25 psi in one or more of your tires. If you check your pressures and find them ok then you may have a sensor problem.
Old Jun 29, 2007 | 10:38 AM
guywade's Avatar
guywade
thankyou thankyou , the sensor is broken , cause the tire looks fine
Old Jun 29, 2007 | 11:03 AM
Mark C5's Avatar
Mark C5
Noooooooooo you can not tell by looking at a runflat tire if it's inflated, that's why they put the sensor system on it. You MUST use a tire guage.
Old Jun 29, 2007 | 11:20 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
You've probably picked up a nail or other foreign item. Use a spray bottle filled with dish detergent mixed with water to spray the tire, then look for the telltale bubbles.
Every time mine's lit up, it's been accurate.
To warning light message LTPWS
