Got a question
Old Jul 3, 2007 | 12:51 AM
calebchoson's Avatar
calebchoson
Default Got a question
If you drop a small bolt down the intake system can it mess your engine up if you turn it on?
Old Jul 3, 2007 | 01:03 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Yes, Big time. What did you do?
DO NOT START THE ENGINE!!!!!
Old Jul 3, 2007 | 01:05 AM
calebchoson
small bolt fell down the runners i took a magnetic tape and stuck it down there but nothing came up. What should i do to get it out?Luckily my battery was dead otherwise id be in deep ****.
Old Jul 3, 2007 | 01:15 AM
black96lt4c4's Avatar
black96lt4c4
what kind of engine
Old Jul 3, 2007 | 01:18 AM
calebchoson
l98 with superram intake. Quick replys are appreciated. Im doing this right now .
Old Jul 3, 2007 | 04:15 AM
toptechx6's Avatar
toptechx6
DO NOT turn the engine over. Keep trying to fish the bolt out with the magnet through the intake, remove the intake if necessary, if you don't retrieve it that way pull the plugs and try a small magnet through the spark plug holes. If that fails you may need to pull the heads, but it is still better than the potential damage if you start it. Good luck.
Old Jul 3, 2007 | 06:12 AM
mseven's Avatar
mseven
if you can't fish it out w/mag tool or whatever, tearing it down till you find it is the only real solution.
Old Jul 3, 2007 | 06:21 AM
conv90's Avatar
conv90
Luckily your battery was dead...
I hope you can "fish up" the bolt.
-Beppe-
To Got a question
