Wheel Locks??? help!!!!!
Old Oct 29, 2001 | 02:47 PM
Izover4u's Avatar
Izover4u
Default Wheel Locks??? help!!!!!
hey guys i was wondering if anyone knows how to break off wheel locks... i got a flat the other day and need to take off my tire and bring it to get new ones...unfotunately i lost my wheel lock key and need to get the locks off.. i would usually just bring it to NTB and they would take it off but my car is sitting in my garage with a totally flat tire... it got a rip in the side wall from a sewer cap...(dam construction) :mad anywayz any help would be great thanks guys :cheers:
Old Oct 29, 2001 | 02:56 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Wheel Locks??? help!!!!! (Izover4u)
If you mean a locking lug nut, go to Sears and get a 12-pt socket just a little smaller, drive it on and it should come off. I saw a guy at the local tire store do this very effectively.
Old Oct 29, 2001 | 03:59 PM
scorp508's Avatar
scorp508
I lost my lock at the dragstrip, and did exactly what 65Z01 prescribed. It worked and they were off in 3 minutes. :)
Old Oct 29, 2001 | 04:27 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
If they're the factory locking nuts, any dealership will have a key and can get it off for you. Plus order another one for you.
Old Oct 29, 2001 | 04:34 PM
khornet's Avatar
khornet
From: Phx/but its a dry blast furnace kinda heat AZ
I was able to go to my local Chevy dealer and they removed all the wheel locks without damaging the wheels, since the previous owner of my vette had lost the key. Cost me $40
Old Nov 1, 2001 | 03:30 AM
Kevin 88's Avatar
Kevin 88
I had these Gorilla locks, nobody could get them off using the socket trick. In fact they couldn't get the socket off either! I had to pay a little old man with a welder to weld a bolt onto each one, then wrench it off. Didn't mar the wheels at all - the old man was good.
[Modified by Kevin 88, 1:31 AM 11/1/2001]
Old Nov 1, 2001 | 01:30 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
If it is the lock to the center cap, I used needle nose pliers and an thin bladed screwdriver to get them off.
Bought a new set with wrench.
If it is a locking lug nut I'd try the other suggestions.
Old Nov 1, 2001 | 03:37 PM
Plasticman's Avatar
Plasticman
Default Re: Wheel Locks??? help!!!!! (jaa1988)
Beware of using the "Socket Trick" when removing locking lug nuts. When you hammer on the socket, the wheel bearing is taking the hits! This causes what is called "brinneling" (indentations of the rollers into the race of the bearing). Replacement of the bearing is the next step.
A Ox-Ac. torch is a far better way to remove the lock nuts, but it must be done by a pro who won't damage the wheel. Most of the time, you only need to heat up the lock nut, and then turn it with a large screwdriver. Don't go cherry red (too hot and you will damage the wheel). Just hot enough to expand the nut and stud. Don't try this with propane (it does not have the heat necessary - you end up heating the wheel and nut, which defeats what you are trying to do, which is get the nut / stud to expand away from the cool wheel so you can turn it).
Plasticman
To Wheel Locks??? help!!!!!
