C4 transmission problems
Old Jul 4, 2007 | 01:33 AM
Saxo's Avatar
Saxo
2nd Gear
Default C4 transmission problems
I have a C4 1991 all org. L98
3 gear with elec. overdrive
when I set it in drive (overdrive) and go op the gears, it only goes to
2. gear and then try to go down 1. gear again.
Does anybody know what to do ????
I'm all
Old Jul 4, 2007 | 08:39 AM
Pete K's Avatar
Pete K
I'm all
If the trans shifts from 1st to second then 3rd gear acts as neutral, the 3-4 clutch pack is shot, thus rebuild time.
If it will not shift from second to third, it is likely in the valve body.
Old Jul 4, 2007 | 09:52 AM
Saxo's Avatar
Saxo
2nd Gear
It dosn't shift to 3rd at all, only tryes to shift down to 1st. no fun at all with 3500-4000 rpm in 2nd
To C4 transmission problems
