Power steering cooler?
There are aftermarket PS coolers available and you plumb them into the return line, no the pressure line. Some are single pass units and some double pass. The best place would be in the stock location (in front of the rack. Fab some brackets and bolt the assembly to the existing braces.
I found these Perma-Cool units at Summit Racing. If the link doesn't work, go to www.summitracing.com and do a search on "power steering coolers".
The picture below shows what I did for a PS cooler, the white arrow points to the PS cooler mounted in front of the front cross member. I bought a Hayden PS cooler and mounted it where the factory cooler is mounted on the later C4's. I plumbed the cooler into the low pressure return side of the system, route the fluid out of the rack into the cooler and then from the cooler into the fluid reservoir. In conjunction with a set of underdrive pulleys I no longer have any PS over heating at the track.
Brian
Anyone put in an oil cooler to? I have my trans cooler out in front of the radiator but my oil temp can still get high. Would an EOC in addition to the stock oil warmer be best?
Here is a picture of my oil cooler mounted in front of the radiator. The second picture shows the oil cooler adapter and some of oil line routing that I used. Since this picture was taken I have routed the oil lines closer to the engine block and farther away from the header tubes. Hope this is helpful.
Brian
I have been running this oil cooler for about 12 years now. When I first started tracking the car, with the stock oil cooler, in 2 to 3 laps I was seeing 280°F oil temps, so I would have to take a couple of easy laps to let the oil temps drop. After putting on the cooler I can run hard for a 20 to 25 minute session on hot days and I will see 260°F oil temps. So it was a worth while investment. The adapter is an aftermarket unit.
The stock oil cooler also mounted between the oil filter and the block, but it is plumbed into the water coolant, water came out of the block just ahead of the oil filter then went into the oil cooler and routed back into the heater hose system. The stock cooler was not sufficient for track use in my experience.
Brian
Rather than going aftermarket, I would suggest calling a quality Corvette recycler and getting a 4 pass GM unit that is correct for your car. Be careful, there are some differences from year to year. My OEM '91 cooler had both entry and exit points on the driver side of the car. While the $20 cooler that a recycler shipped me from LA had the input line from the rack on the driver's side, it had an exit line (that goes back to the resevoir) that was on the passenger's side (different than mine).
However, it was simple to route a 3 foot length of 3/8" low pressure PS hose from the passenger side of the car to the return opening on the PS reservoir. In doing this, I eliminated GM's strange OEM "S-turn" hose that snaked around the front sub-frame. This should help with future leaks, as there are now two less hose clamps and one less rubber hose in the system.
In doing my replacement, I took the alternator out so that I could put a new right angle hose fitting with a new hose into the exit fitting from the rack to the cooler and clean things up a little more easily. My OEM PS cooler had been damaged and was leaking from its encounter with a largish western desert road rock.
If I had to put another OEM cooler in and my inlet hose from the rack to the cooler was definitely not leaking, I would just do everything from below the car and use doubled-up hose clamps on the two rubber hoses that route to/from the PS cooler. That job would have taken much less than an hour.
I didn't have any problem in priming the old pump after re-installing the reservoir and routing the new hoses to the cooler. Running the engine about 2000 rpm and moving the steering wheel lock to lock about ten times over ten seconds seemed to do the trick. It was very hard to move the steering wheel before the pump primed itself. I couldn't imagine driving the car without power steering.
