Power Antenna Promblems
Old Jul 4, 2007 | 06:25 PM
torchedred's Avatar
torchedred
Default Power Antenna Promblems
On my '94 hardtop corvette, the antenna goes up and down but when I shut the radio off the antenna stays up about two or three inches. One will this made my battery go dead and what is the easiest way to replace the antenna?
Old Jul 4, 2007 | 07:08 PM
Keystring's Avatar
Keystring
I would pull the insert out and check for broken teeth on it.
Might be what is causing it to jam.
Old Jul 4, 2007 | 07:27 PM
cdnguyred88's Avatar
cdnguyred88
I had the same problem 5 or 6 years ago. Not really hard to replace the mast if it is broken. If you can get a helper to turn the radio on and off as you thread the old 1 out and new 1 in, it makes it alot easier to do.
Old Jul 4, 2007 | 08:07 PM
Da Mail Man's Avatar
Da Mail Man
Old Jul 5, 2007 | 08:41 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Check the C4 TechTips section on this Forum. There's an article there that can help you.
Old Jul 6, 2007 | 10:10 PM
torchedred's Avatar
torchedred
Default RE: Power Antenna Promblems
I dont mean to sound stupid but where on the site are you looking at the C4TechTips section? I haven't been able to find it.
To Power Antenna Promblems
