4+3 Clutch Slave Question
Old Jul 6, 2007 | 02:31 PM
CAJUN C4's Avatar
CAJUN C4
Default 4+3 Clutch Slave Question
For all you 4+3 guys. Seems like in my 84' I'm changing the Clutch Slave Cylinder every 3 years or so.Is anyone haveing better longevity than this? Also, I'm thinking about,this time, just putting in the soft goods kit.$9.00 vs $90.00 for a complete unit.
Old Jul 6, 2007 | 03:47 PM
Great White North's Avatar
Great White North
some of mine only last a year.I was unable to find the soft parts kit.
Old Jul 6, 2007 | 04:12 PM
CAJUN C4's Avatar
CAJUN C4
"A year"......I wonder why...Is it the heat? using Brake fluid instead of Clutch Fluid? My 96' is original...Strange.I thought I found a Kit from Advance but I found out it was obsolete and not available as well.
Old Jul 6, 2007 | 04:44 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
You may want to try using the GM fluid, it may help it last longer.
Old Jul 6, 2007 | 04:46 PM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
Originally Posted by CAJUN C4
.......... Also, I'm thinking about,this time, just putting in the soft goods kit.$9.00 vs $90.00 for a complete unit.
Mine's leaking too and due for a rebuild or replacement. Where did you find a rebuild kit for it?
Old Jul 6, 2007 | 04:47 PM
CAJUN C4's Avatar
CAJUN C4
I might try some.Might be better than Dot 4 Valvoline Synthetic.
Thanx
Old Jul 6, 2007 | 04:54 PM
CAJUN C4's Avatar
CAJUN C4
I thought I found one at Advance Auto.They have 3 listed but when I went to place my order it rejected it because they couldn't get any of the 3. I have ordered a new complete one $81.00 from Advance.
Old Jul 6, 2007 | 05:15 PM
CAJUN C4's Avatar
CAJUN C4
You may have something here. GM Clutch Fluid,P/N: 12345347, has the correct additives etc.better lubricates the seals, extends their life and resists air entrapment better than Brake Fluid I was told.
$12.00 List $7.11 at GMpartsdirect.com
Old Jul 9, 2007 | 02:44 PM
CAJUN C4's Avatar
CAJUN C4
Default 3-4 Years Max
I might wrap the Left exhaust pipe with some insulation as it is directly in front and below the Slave Cylinder.I bet heat is the culprit causing the Slaves to not last very long.I bet it would help.I don't know weather they use Buna or Viton Seals but Buna is only good for about 180 F and Viton 450F.
Old Jul 10, 2007 | 06:52 AM
CAJUN C4's Avatar
CAJUN C4
Well,having trouble bleeding the new slave cylinder of course. FSM says to hold the slave at a 45 degree angle with the bleeder valve pointing upwards. Anyone else have a pain in the butt time getting all the air out? Were gonna try again tonight.I remember 4 years ago, on the last replacement, it took forever.
Old Jul 10, 2007 | 09:00 AM
CAJUN C4's Avatar
CAJUN C4
ttt
Old Jul 11, 2007 | 10:56 PM
mikeb's Avatar
mikeb
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
My Chilton's manual says to use Dot3 Brake fluid.
Old Jul 11, 2007 | 11:02 PM
mikeb's Avatar
mikeb
I just replaced my master cylinder, and the Chilton's manual says the same thing about 45 degrees. I didn't do that step, and I think I got some air left in because my clutch catches about 1/2" from the floor board (very low). I'd like it to be a little higher, maybe another 1/2".
But when I open the bleed, a steady stream of fluid comes out until the pressure is relieved, no air.
When bleeding, I had my helper (The wife) pump it 20 times and hold the pedal in, bled it, and released the pedal. Filled the cup, pumped 10 times then bled, and repeated 2 more times.
Old Jul 12, 2007 | 08:43 AM
CAJUN C4's Avatar
CAJUN C4
Very Important Step.
"I didn't do that step, and I think I got some air left in because my clutch".
This is a MUST !!! 45 degrees.
To 4+3 Clutch Slave Question
