idle problem on a 1985
Old Jul 6, 2007 | 04:11 PM
marks 85's Avatar
marks 85
2nd Gear
Default idle problem on a 1985
hi,it idles fine 75% of the time but sometime its a little ruff.i have putt on new injectors,tp senser,fuel pump,plugs,wires,cap,rotor,mass air senser.i myself is looking at the idle air valve,but i have never done one of these and was wandering how best it is to do one?or if i am even close to the problem.thank for your time with this,mark
Old Jul 6, 2007 | 05:30 PM
All2kool's Avatar
All2kool
MAF. Disconnect it, reconnect it.
Old Jul 6, 2007 | 07:28 PM
marks 85's Avatar
marks 85
2nd Gear
i will try that,thank you for your time,mark
Old Jul 6, 2007 | 10:55 PM
champs65's Avatar
champs65
Maybe brittle/cracked vacuum lines leaking or disturbed with all the parts you've been replacing on the top of the engine as well.
Old Jul 6, 2007 | 11:14 PM
larryfs's Avatar
larryfs
Old Jul 7, 2007 | 01:32 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Jumper diagnostic pins A & B (top right)
Turn key on, wait 30 seconds
Unplug idle air control (IAC) valve connector.
Remove diagnostic jumper.
Start car
Adjust idle set screw to 450 rpm
Shut car off
Plug in IAC connnector
Done.
To idle problem on a 1985
