How do you remove the shift knob on a 6 speed
Old Jul 7, 2007 | 02:18 PM
Raidmagic's Avatar
Raidmagic
Default How do you remove the shift **** on a 6 speed
I have a friend that can't get his to come off, what's the trick? It's a 94 if that matters.
Old Jul 7, 2007 | 02:25 PM
Carpenter's Avatar
Carpenter
Carefully pry up the plastic cover with a small screwdriver (it's just friction fit).
Pull out the metal wedge shaped pin with pliers.
Unscrew ****.
Old Jul 7, 2007 | 02:40 PM
Raidmagic's Avatar
Raidmagic
Old Jul 7, 2007 | 03:13 PM
Irishpilot03's Avatar
Irishpilot03
instead of pliers, I took a thin piece of sheet metal and put an 1/4" right angle bend and it pulls the pin right out.
To How do you remove the shift knob on a 6 speed
