code 26 on a 93
Old Jul 7, 2007 | 10:57 PM
93txvette's Avatar
93txvette
Default code 26 on a 93
Car is running really rough. Seems to run better once i get the rpms up. Have checked all that comes from the code, or atleast I think I have. Replace EGR valve cause it was bad. Checked and replaced AIR pump relay. Was cheap enough to replace without much worry. Checked lines on my purge cylinder. Everything seems to be in working order. Anymore suggestions.
Old Jul 9, 2007 | 08:01 PM
wingstlr's Avatar
wingstlr
I have the same code but my car still runs good just started to track it and tranny started messing up so now my tranny is a bigger problem than my code 26. Keep me posted on what you find and i will the same for you if i track it down.
Old Jul 14, 2007 | 10:29 PM
93txvette's Avatar
93txvette
ty will do. maybe something will come up and can get this figured out
To code 26 on a 93
