Frustrated with over-engineered C4
Yesterday I pop the hood on my 85 (that alone took about 45 minutes and an adjustment to do) and there they are in plain sight. 8 nuts, a couple of grommets, work em around a couple of wiring harness's. No problem. Right?
Well, the left side wound up hitting the ultra stupid, completly worthless AIR pump in the front by about 1/2 inch and a metal vacume tube in rear by about the same amount.
By 1985, GM new full well that their small block V8 valve cover gaskets leak oil and they couldn't find it in their hearts to engineer easy replacement of them.
I'm ready to either find a way of stripping this car of it's stupid meaningless hardware or cash it in on a C3 and go old school.
I did the valve covers on my 86 and know EXACTLY what yer going through. I ended up pulling the AIR pump and the vacuum tube off to clear the left side valve cover. The right side was the hardest for me, though. You have to remove the EGR pipe first, and then it takes a lot of wiggling (and cursing
) to get the cover off. Getting them off was the hard part, putting 'em back on was easier. Once yer done you'll feel better, trust me
It does in on the '84 too. But ours is easy to disassemble the top of the engine and have a clear shot on both sides.
It doesn't get any better for the 92 LT1. Right side you need to remove the AIR pipe which is no fun. On the driver's side you need to move the alternator and A/C bracket to make room to remove the cover. Just thank your creator that you are not replacing the heater core.
I did an internship at Land Rover North America HQ and I asked the engineers about stuff like this. With little exception, no consideration is given for service in the design and layout of an automobile. Ther were several reasons given, I will spare the details, they all made sense, cost of production and fitting the package is paramount.
So, I learned a long time ago that everything in the way is actually easy to remove. I tried to avoid it to "save time"
This certainly adds steps, but it is better than fighting stuff all the time. If it's in my way, I take it off right from the start.I remember a 25yr vet working on a very old 50's caddy and while getting a 3/4 turn at a time on bolt (a brake line was in the way) he laughed said "I bet they bitched up a storm in the 50's about how tight the compartments have become".
A person really needs to fully understand the ramifications of removing emission components prior to doing it. Especially in California.
It took me two-and-a-half-hours to do that side. It took me an hour and 15 minutes to change the passenger side wires and ignition coil wire.
No way in hell should routine tune-up items be this difficult. If it were any other car other than a Corvette, I'd have sold the damned thing a long time ago. Call it a labor of love.
I dont blame you, they are very sweet, and in some respects look easer to work on. I was looking at one at a local car show the other day thought, and the old distributor with points just doesnt look like any fun either.
would you pick a chick who's gorgeous, but rotten and ready to fall apart inside?
ALSO when you replace them spend the money and get the NICE rubber coated ones from Fel Pro that have the metal core. I purchased these at AutoZone for just under 20 bucks and MAN are they NICE and not a drop of oil leaking since they were replaced.
GOOD LUCK!
