Lt1 won't idle????? HELP
Old Oct 30, 2001 | 11:45 AM
72CheyeneLT1's Avatar
72CheyeneLT1
Default Lt1 won't idle????? HELP
I put a 92 LT1 in my 72 chevy pickup truck. I removed the EGR system from it. It will not idle and I can keep it running only be pumping the accelerator. It will start and if I don't pump the accelerator to keep it running it will die. I have a new painless wiring harness and VATS bypass module. It does the same thing whether the vats is hooked up or not. Could it be bad. Is that how the VATS works? Also I get four faults from the computer. 26 EGR(which I am not using), 27 TCC (which I am not using), 28 and 66 which both have to do with the AC which I am not using also. Will not having the EGR hooked up cause that? ALso I am starting it with open headers and they are very close to my knock sensors could the noise from the headers be cusing the knock sensors to retard the spark or fuel? That is all I can come up with. I will appreciate any help I can get.
Thanks, Dave :confused: :confused: :cry :cry :flag
Old Oct 30, 2001 | 01:53 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Lt1 won't idle????? HELP (72CheyeneLT1)
Have you set the IAC motor and the idle on the throttle body? Other than that, check for vacuum leaks, and/or fuel delivery.
Old Oct 30, 2001 | 02:11 PM
72CheyeneLT1
Default Re: Lt1 won't idle????? HELP (Vette92)
Yes I have reset it about 3 times and it seems to get a little better each time but it still won't idle. Thanks for the tips.
Dave
Old Oct 30, 2001 | 02:41 PM
72CheyeneLT1
Anybody out there?? :cool:
Old Oct 30, 2001 | 06:32 PM
72CheyeneLT1
Nobody has any ideas?
Old Oct 31, 2001 | 04:45 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Is the engine coolant temp sensor on the water pump connected ?
Old Oct 31, 2001 | 09:18 AM
72CheyeneLT1
Default Re: Lt1 won't idle????? HELP (AquaMetallic94LT1)
Yes
Old Oct 31, 2001 | 07:09 PM
GlockLT4's Avatar
GlockLT4
It shouldn't be the VATS emulator. If the vats was messing up the computer, then it wouldn't let you start it at all...
[Modified by Glock'94, 5:09 PM 10/31/2001]
Old Oct 31, 2001 | 07:26 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Can you scan it to see if the TPS is reading correctly? If it is not, it will hunt like a dog.
Chris
Old Oct 31, 2001 | 10:23 PM
KYVette90's Avatar
KYVette90
I know how you can fix it! Start by raising the engine up with a cherry picker. Then role the truck out from underneath it. Then role a 92 Corvette, minus the engine, under your engine. Lower the LT1 engine into the hollow Corvette and it should work. Hope this helps. :jester
Old Nov 1, 2001 | 04:46 PM
72CheyeneLT1
Default Re: Lt1 won't idle????? HELP (KYVette90)
I will try the TPS. Thanks
Does anyone think it could be a vaccum leak?
:U KYVette90 L98
[Modified by 72CheyeneLT1, 8:46 PM 11/1/2001]
Old Nov 1, 2001 | 08:43 PM
KYVette90's Avatar
KYVette90
I think it could be a vacuum leak. :conehead
To Lt1 won't idle????? HELP
