Bleeding The Clutch
Old Oct 30, 2001 | 02:25 PM
LSCHMIDT's Avatar
LSCHMIDT
Default Bleeding The Clutch
I have to replace the clutch master cylinder (leaking) on my 94 6-speed. It looks like I have to pull the slave cylinder because it needs to be upside down to bleed it (Who designed this?). Are there any tricks to this?
Old Oct 30, 2001 | 06:18 PM
MarkBychowski's Avatar
MarkBychowski
Default Re: Bleeding The Clutch (LSCHMIDT)
You have the right idea, you'll need to turn it upside down to properly bleed the unit. Bleeding is pretty simple -- exactly like pump-bleeding brakes. I let mine gravity bleed for a while first, just to make sure all the old fluid was flushed out.
Old Oct 31, 2001 | 02:18 PM
LSCHMIDT's Avatar
LSCHMIDT
Default Re: Bleeding The Clutch (MarkBychowski)
Thanks for the reply. I replaced the clutch master cylinder last night , but didn't bleed it yet- my helper was not available. It looks like the slave cylinder will be hard to turn upsidedown.
To Bleeding The Clutch
