Slave Cylinder Bleeding a PITA
Old Jul 10, 2007 | 02:06 PM
CAJUN C4's Avatar
CAJUN C4
Default Slave Cylinder Bleeding a PITA
Started bleeding the clutch slave on the 84' last night boy what a pain.
My FSM states it must be held on a 45 degree plain with the bleeder directly on top.
Anyone have trouble with this? After about an hour of bleeding I only have about half a pedal.Any Tricks?
Old Jul 10, 2007 | 03:03 PM
FlyboyZR1's Avatar
FlyboyZR1
I remember bleeding the slave on my '86 was somewhat difficult. I think I ended up bleeding it off the car with a trick someone here posted that ended up working ... try searching the archives.
Old Jul 10, 2007 | 06:28 PM
Great White North's Avatar
Great White North
It can be a real pain.You can park the car on an incline or jack the front end up.I had my best luck using a Phoenix bleeder and drawing it down through the bleeder.
Old Jul 10, 2007 | 09:21 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
After working it with the pedal, put a rag under the master cylinder.
Get underneath and hold the slave with the hose fitting at the highest point.
Push the slave rod/piston in by hand to force the fluid and air up to the master cylinder. This may cause the master to overflow.
Get into the car and slowly pump the pedal up again to extend the slave piston until there is resistance. Watch the reservoir, it will drop fast, make sure you don't draw it dry.
Now pedal bleed it again.
If it's not rock hard, repeat.
You should get 3/4" of travel at the fork end when all is said and done.
I don't bleed clutches with the slave installed if I don't have to. It makes it hard to tell if there's air in the lines or just the pressure plate moving.
Old Jul 11, 2007 | 09:12 AM
CAJUN C4's Avatar
CAJUN C4
Bingo Great White!!!!
We were successfull drawing fluid out with a Mighty Vac Pump. The pedal was hard as a rock not installed.However, when we test drove it the pedal became softer & softer until I couldn't shift it.It's my 9 month old Master cylinder that is the culprit. I screwed up assuming it was the 4 year old slave.You'd think after 58 years one would know better.
Oh well,1 year warranth at Advance.Anyone have trouble with Advance Auto's Cylinder products?
Old Jul 11, 2007 | 12:33 PM
GRX's Avatar
GRX
Master Cylinder - If its the ~$80 cheapie then YES. Mine lasted about 20 miles. The internal valve was failing....pumping into the reservoir. Get the GM "reproduction" which is about ~$140. I've been very happy with it. It installs better too.
Old Jul 11, 2007 | 12:36 PM
CAJUN C4's Avatar
CAJUN C4
How about the Master Cylinder. What's the best?
Old Jul 11, 2007 | 12:47 PM
GRX's Avatar
GRX
GM reproduction on bottom of pic...
Old Jul 11, 2007 | 01:12 PM
CAJUN C4's Avatar
CAJUN C4
Where do you get the GM Repro's?
Old Jul 11, 2007 | 01:55 PM
Great White North
notice the two different hole sizes in the rod...the first time I did one I never noticed until it was in the car!!!
Old Jul 11, 2007 | 02:39 PM
CAJUN C4's Avatar
CAJUN C4
The bottom on has a nylon insert probably to fit other applications. I just pulled mine out and it fit just fine.
Old Jul 11, 2007 | 02:41 PM
Great White North
I wasn't so lucky ,the one I got was solid.
Old Jul 11, 2007 | 02:43 PM
CAJUN C4's Avatar
CAJUN C4
That's strange. I'm gonna try another one. It's still under warranty. Not very hard to R & R.
Old Jul 11, 2007 | 02:44 PM
CAJUN C4's Avatar
CAJUN C4
GRX...Where did you get the Better GM Repro From?
Old Jul 11, 2007 | 06:25 PM
GRX's Avatar
GRX
I got mine from the local "Corvette Clinic" here in San Jose. I'm guessing that maybe Eckler's would have them.
Old Jul 11, 2007 | 10:25 PM
XLR8TIN's Avatar
XLR8TIN
See
www.zfdoc.com
To Slave Cylinder Bleeding a PITA
