ASR/Service engine Light
Old Jul 10, 2007 | 05:32 PM
KJ5ZV1's Avatar
KJ5ZV1
5th Gear
Default ASR/Service engine Light
Hi group,,, Here is the issue, I can start the 92 and runs fine, does not activate lights. The next time I start, 30 min or so, it starts with high idle, no A/c, no speedometer, security light flash, ASR/ Service engine light. Found a thread here that suggested ECM, and I agree as I would tap the top and it would sometimes kill the engine. I replace with a new rebuilt. Prior to that it would start with the lights already activated. Pulled the codes and they indicate:
1.1 H-41
9.1 H-72
Have the list of all the other codes if needed,,,but those were the two that listed a code. Any suggestions as to where to look would be appreciated. Bill
Old Jul 11, 2007 | 07:43 AM
kalister1's Avatar
kalister1
The H means a HISTORY code, used to there but is OK now. Pull the battery cable off for a couple minutes and they will go away. I take it that replacing you ECM fixed all the problems?
Old Jul 12, 2007 | 09:09 AM
KJ5ZV1's Avatar
KJ5ZV1
5th Gear
Default Not quite
Sorry I was not clear in my post. Replacing the ECM did stop the ars/se light on first start up of the day. It returns the very next time I start the car after the first use, sort of like when the car has warmed. I also said the other codes,,,, well they did not throw a code, I can read the info or have ---- So I realy only have the two codes mentioned previously. Still could use help as to where to start. thanks for the reply. bill
To ASR/Service engine Light
