Lowering Questions???
Old Oct 30, 2001 | 06:42 PM
GS 163's Avatar
GS 163
Default Lowering Questions???
Im thinking of lowering my car with the bolt and shim kit. Got thinking and was wondering if the 11 inch wheels will rub on the fender in the back. Anyone with this set up, and how much clearance do you have?:)
Old Oct 30, 2001 | 09:56 PM
GS 163's Avatar
GS 163
Default Re: Lowering Questions??? (JPLT1)
anyone????
Old Oct 30, 2001 | 10:29 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Nat96LT4 has his lowered a couple of inches with the large rear tires...
Old Oct 30, 2001 | 10:41 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: Lowering Questions??? (Springer's 95)
One of the wheels guys I've been speaking with said it was ok to go an inch in the rear as long as you have 315-35-17 and not 335s.I haven't done it but I'm planning it on mine. In case I missed it, any luck on a source for the headlights and foglights? I want to upgrade in about 3 weeks.
92TripleBlack :cheers:
Old Oct 30, 2001 | 10:44 PM
GS 163's Avatar
GS 163
Default Re: Lowering Questions??? (92TripleBlack)
Lights should be here by the end of the week.
Old Oct 31, 2001 | 01:24 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Some may rub but it is negligible. No one can see it anyway, and yes I show my car too.
Old Oct 31, 2001 | 01:27 PM
GS 163's Avatar
GS 163
Default Re: Lowering Questions??? (Vette92)
Chris
Didnt you leave the shims out of the front all together? If so, do you get any rubbing on the front? I want to go as low as possible, but not to excited about rubbing tires.
Old Oct 31, 2001 | 02:08 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
I had removed the shims completely from the front of my Aqua car (sold). It did rub the underside of the hood. I am not sure I would go that low again, especially on a vert. It did look cool though, just have to worry about hitting road bumps way too often.
My blue car, I just lowered the back as the front sits just fine. Some sit higher than others and if it sat high I would probably lower it and use the shims when I reinstalled the spring.
Chris
Old Oct 31, 2001 | 03:26 PM
Mikez40's Avatar
Mikez40
I lowered my rear a few weeks ago, about an inch. No rubbing, and I have the 315" on GS 17x11 rims.
To Lowering Questions???
