Finally coming to the end of my timing chain gear set install and pan repair.
Tried installing the Harmonic Damper last night. I am using the correct installation tool, and a fairly large adjustable wrench (the nut on the tool must be a 1").
This thing seems to be a little rough to put on. I got about 1/4 inch more to go, and it looks like I'm going to have to jam a screwdriver or something in the flywheel to keep the engine from turning. I think I am seeing some metal shaving dust coming off the tool as I crank on it.
The wrench has a 10-12 inch handle, and I'm pulling on it pretty good.
Are these things this tough to install, or is something wrong? When I have had to put this kind of effort into something in the past, It usually broke. Just looking for someone to tell me "Yes, you are a wimp"
take it off again inspect the hub for damage if its OK ,just put a bit of lube on the hub and make sure when your pressing it on its going on strait and even.it takes a bit of muscle but should go on nice and smooth with out binding you should have to stop the crank from spinning when installing it thats normal
if its a new balancer it should be honed to fit, dont force it on .any engine shop should do it for a few bucks
NEVER, NEVER, NEVER, hone the bore of a vibration damper. It is the tight press fit that allows the vibrations to be transmitted from the crank to the damper and allows the dampening to take place.
Make sure you have no metal shavings or dust coming from the crank or damper; from the tool, is OK. It can help if you boil the damper to heat it and expand the bore, slightly. Don't use a torch or other means to get it hotter, because you can damage the rubber elastomer that bonds the ring to the hub. I've never tried it but an ice pack on the snout of the crank for a while couldn't hurt, either.
RACE ON!!!
i meant on a new aftermarket balancer you might have to .many times you do have to hone to get the right press fit .especially ati balancers ,it even says it in the instructions .
Yes, unless it's the aluminum one. ATI says not to hone those.
I just installed a ATI Super Damper (274) a few weeks ago on my new 388 LT1 engine and that sucka was a TIGHT fit, and I mean TIGHT!
My EAGLE crank has double Woodruff keys when increased the resistance even more.
I had to use a big pipe wrench and plenty of muscle, but it went on smoothly, but only a little at a time.
And, yes, I had to wedge a big, flat blade screwdriver in the rear (using flexplate bolts, screwed into the crank, to wedge it) to keep the engine from turning.
Jake
they should have a 2 thousand press fit but most come about 4-5 thou undersized .so it has to be honed to get the 2 thousands press fit especially when you bolt it on a eagle crank its a tight fit.even a stock balancer you might have to hone to get it to fit .its true you never hone a aluminum balancer .me 2 other guy 0
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
Frank,
Agree with you on that. Having installed two new ATI super dampers on 2 different cranks, I found about .004 " under on the steel hub requiring honing to get the .002 " press fit as directed in the ATI instructions. I have seen the results of a .004 to .005 " press fit on a crank that a friend attempted and it wasn't pretty. Metal shavings and gouges in both crank and damper. It would be wise to always measure the crank and new damper before install to determine proper press fit when using new parts whether OEM or Aftermarket. I have also seen new and used crank hubs vary as much as .002" on the O.D.
Frank,
Rick
thanks for confirming that for everyone ,it sure is fun trying to get a balancer on that's 4 thou press fit .you destroy the balancer and could damage the crank snout ,so much for"you never hone a balancer".that recommendation could of cost a few guys a lot of headache and money.btw in your avatar are the front wheels off the ground on that launch?
If you're really having to crank down hard on the hub tool, stop. You run the risk of snapping the tool's threaded bolt end inside the crank snout, or stripping the threads. The inner bolt's head ot the tool is taking up all the rearward pressure. Pull the balancer off, and clean the crank snout/balancer hole with fine grit sand paper. It should go on relatively easy.
Once I secured the engine with a screwdriver jammed betwen the flywheel and the ground, the balancer went on using the same effort the rest of the way. It was tougher then I expected, but lubing the tool threads and compression ring seemed to help.
Got the dampner on and the car is running smoother then I can remember. We'll give it the full test drive into work tomorrow, but looks like I passed through this aweful job with plenty of help from CF.
RACE ON!!!
read post 8,9,13 you should always check the press fit on a balancer even a stock replacement balancer might need to be honed to get the .002 thous press fit.you NEVER NEVER NEVER force a balancer on to the crank snout,measure the fit and if it needs, hone for a .002 press fit.you cant say NEVER NEVER NEVER hone the damper bore .that is not true and could cause serious damage to balancer and crank.me 2 other guy 0
I concede that "NEVER, NEVER, NEVER", was a foolish thing to say. Never say never. My advice was aimed at the original poster's question using stock parts. The old school advice was to never hone a damper and ruin the correct press fit for the efficient transmission of harmonics, just for the ease of installation. Also, I was unaware that high performance replacement parts manufacturers were recommending a "blueprint" fit. A good idea. The old school advice was from the olden days before the common usage of Korean dampers on Chinese crankshafts. I concede, I stand corrected. I NEVER, NEVER, NEVER, should have said, "NEVER, NEVER, NEVER". There is no doubt checking for a proper press fit is the proper route to take.
Originally Posted by etown brawler
.me 2 other guy 0
Wrong! You 1/2. This one. You get zero for the last one because you never could grasp what I was saying. Twice, you accused me of saying something I didn't. Even after three explanations, you have no idea what I said. You 1/2. Me 1 1/2.
